Topic: digital i/o pins (Read 3066 times) previous topic - next topic
tusharunjha
In the technical specification the Digital I/O Pins are   8. So which pins are used as a digital input or output?
manor_royal
Technical specification of what?
Any digital pin can be either an input or an output, if that's what you mean. Specify direction with pinMode().
If this was a Civil Engineering forum would there be posts like "I need to build a bridge. Someone send me drawings."
tusharunjha
But in MKR1000 Technical specification
it wrote Digital I/O Pins   8.
manor_royal
Presumably the ones marked 0-7 on the board.
Gabriel_swe
This one? https://store.arduino.cc/index.php?main_page=product_info&products_code=GBX00011
0-7 is digital
A0-A6 is analog
~ indicates pwm capable pin.
tusharunjha
But led is blinking from 0 to 14 pins and A0 TO A6 PIN.
In datasheet  of MKR1000 8 I/O pins.
So which pins are considered as a digital i/o pins?
ballscrewbob
@ tusharunjha
All the documentation you should need is HERE
The analogs are essentaily ADC's so can also be used as I/O IIRC.
Some pins can have multiple uses depending on how you call them in your sketch.
Bottom line they are all I/O in some form.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
RedDragon
what does that little ac mark mean beside pins 2-5?
Gabriel_swe
Do you mean the tilde symbol mentioned in answer #4 above?
RedDragon
Ok so that mark means its a PWM pin, but the page for the MKR1000 says that pins 0-8 are PWM pins so why does just pins 2-5 have that mark?
