Topic: Stepper Motor Not Turning with EasyDriver and Arduino, Only Vibrating (Read 6501 times) previous topic - next topic
leejasper851
It turned out that the power supply was the problem. I connected the EasyDriver power supply to a laptop charger and the motor turned nicely. Now my only question is: What is a good portable power supply (preferably not too expensive or heavy)?
leejasper851
Today, I tried the laptop charger again, but a spark came, so I guess that's too much voltage? Anyways, I still need a portable power supply. Preferably one that I can power all 4 stepper motors with one instead of having to buy 4 of that power supply.
leejasper851
I am changing the stepper motor I am using to this: https://www.pololu.com/product/1206. May you please post a good power source (connected to EasyDriver) for this motor?
PaulS
Quote
That's good.
Quote
If it worked before, it isn't. Sparks happen when you have a short circuit.
Quote
What, exactly, are you building? Stepper motors are not really intended to be driven by batteries.
leejasper851
I'm building a robot that climbs stairs, so the power source will need to be portable.
leejasper851
Also, I would prefer it to be rechargeable, but if that isn't available, then I don't need it. Do you think lithium polymer batteries would be a good idea? Do you think this would work?: https://www.amazon.com/HitLights-Rechargeable-Lithium-Battery-Strip/dp/B007RQW5WG/ref=sr_1_2?ie=UTF8&qid=1487906283&sr=8-2-spons&keywords=12v+rechargeable+battery&psc=1
leejasper851
I was wondering: can I use ordinary 12V batteries, or do those not work with EasyDrivers and stepper motors? Also, can i use a battery pack with multiple batteries in one like this one?: https://www.amazon.com/CO-RODE-Battery-Holder-Wired-Switch/dp/B00VE7HBMS/ref=sr_1_8?s=electronics&ie=UTF8&qid=1487991928&sr=1-8&keywords=12V+battery
leejasper851
Could I use 2 9V battery holders and combine the outputs together to attach to the EasyDriver?
Here is the battery holder:
https://www.amazon.com/5pack-Battery-2-1mm-Arduino-Corpco/dp/B01AXIEDX8/ref=sr_1_1?rps=1&ie=UTF8&qid=1479048072&sr=8-1&keywords=arduino+9V+battery+adapter&refinements=p_85%3A2470955011
Here are the batteries:
https://www.amazon.com/EBL-Battery-Charger-Rechargeable-Batteries/dp/B00ER10DZ0/ref=sr_1_3?ie=UTF8&qid=1488031989&sr=8-3&keywords=2+rechargeable+9V+batteries
If I can you that, what would be the best way to connect metal wire to the barrel plug?
PaulS
Quote
Yes. Just don't expect anything useful to happen.
What part of STEPPERS NEED A LOT OF CURRENT don't you understand? 9V batteries are a good deal - for the manufacturer and the retailer. They are a crappy deal for the consumer - they offer the lowest current/dollar ratio of any battery on the market.
leejasper851
In that case, can I use 8 AA batteries like I mentioned before?
PaulS
You are welcome to try. I have my doubts about you being satisfied with the performance.
leejasper851
What's wrong with AA batteries? Do they also have low current?
geko_arduino
had same problem, wiring ok, separate elec supply.
solution was to import the Libraries
from menu ( sketch ? in french Croquis), include library, import a zip , take it from CD
then libraries again, find the new imported library
#include <Stepper.h>
#include <IRremote.h>
#include <IRremoteInt.h>
in my case was missing the last one.
works ok now...
good luck you who enters here, there is still hope!
