Topic: controlling servo with keypad (Read 714 times) previous topic - next topic
Abdulrahman_alrawi
Hello, i want to connect 2 continuous rotational servos with 4*4 keypad, and the keypad determine the angle each servos goes to
​could you help me with the code please?​
 :smiley-sad:
J-M-L
Yes we could. show us where you are from your own research and what questions do you face
Hello - Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums.
Bonjour Pas de messages privés SVP, postez dans le forum directement pour que ça profite à tous
PaulS
Sure. You post the code that you have. You explain what it actually does, and how that differs from what you want, and we'll help you fix it. We won't write the code for you, though.
Abdulrahman_alrawi
I'm using this code, i want the servo go to the desired position and go back to the initial position after few seconds
the code;
#include <Keypad.h>
#include <Servo.h>
int pos = 0;    // variable to store the servo position
Servo myservo;  // create servo object to control a servo
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the symbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
String value = "";
void setup(){
  myservo.attach(10);  // attaches the servo on pin 9 to the servo object
void loop(){
  char customKey = customKeypad.getKey();       // get the key pressed
  if(customKey=='1'){                            // 'D' works as "enter"
       for(pos = 0; pos < 60; pos += 1 )           // goes from 0 degrees to 180 degrees
  {                                               // in steps of 1 degree
     myservo.write(0);                          // tell servo to go to position in variable 'pos'
    delay(15);                                  // waits 15ms for the servo to reach the position
Abdulrahman_alrawi
I want the servo go to the desired position and go back to the initial position after few seconds (my project is to control to servos with keypad such as entering A and 1 will rotate the first servo by 60 degrees)
the code;
#include <Keypad.h>
#include <Servo.h>
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
String value = "";
void setup(){
void loop(){
PaulS
You need to re-read Reply #2. Read it several times, if necessary. We still do not know what the code ACTUALLY does, or how that differs from what you want.
UKHeliBob
You can want it all you like but you cannot make continuous rotation "servos" go to a particular angle.  The value written to such servos determines the speed and direction not the position.
Why not use conventional servos.
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
