sizeof struct between ATmega328 and ESP8266
Hi!
compiled for an ArduinoUno this struct has a size of 3 byte:
struct SensorData {
    signed int temp : 12;
  unsigned int ldr  : 10;
  unsigned int bad  : 1;
When compiled for ESP8266, it has a size of 4 byte. Even with this modification:
struct SensorData {
  int16_t  temp : 12;
  uint16_t ldr  : 10;
  uint8_t  bad  : 1;
What can I do, to have it three byte long on ESP8266 ?
Thanks in advance,
Detlev
You could maybe try packing pragmas, but why is it important?
Probably nothing. The bit count information is a suggestion to the compiler, not a requirement that it must implement.
Get rid of that, and live with a 4 byte struct on both platforms.
It would result in 24*60=1440 unused byte in RAM and it also would need a more complex function for sending the entire array to a python-script (which expects a single sensordata in a length of three byte).
So, do the packing yourself.
That implies that you are using more than 4320 bytes of SRAM on the Uno. How is THAT possible?
PaulS:
On the Arduino, this data resides on two EEPROMs. 4KB in AT24C32 and 1KB inside of the ATmega328.
struct SensorData { ... } __attribute__((packed));
oqibidipo:
That works!
Thanks :slight_smile:
I think packing will make access to your array of structures less efficient for the ESP8266. This is because members of some array elements will likely span 32-bit word boundaries. But, if memory use is more important in your application than processor cycles, then it should be OK.
