Moving forward in my project. I replaced the breadboard with a custom circuit card.
Still have the flicker.
Went through and turned off all controls but dimmer. no flicker.
Turned on other controls one by one.
The DHT sensor function is causing the flicker. No doubt about it. Not sure why. Will read further into the DHT library.
If anyone knows of any conflicts between the DHT library I am using and external interrupts or other function of turning on pin 3 which drives a triac, (assuming the problem is in one of these areas) please let me know.
Here is my code.
//Incubator Control
//by Ted Hardwicke
//2016
//temperature sensing, egg turning motor control, heater control, display control
//Libraries
#include <PID_v1.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include "DHT.h"
#include <LiquidCrystal.h>
// Pin assignments
#define DETECT 2 //zero cross detect
#define GATE 3 //triac gate
#define motorPin 4 //Motor on/off
#define DHTPIN 5 //DHT sensor input
#define dayIncrement 6 //DHT sensor input
#define dRs 8 //Display register S
#define dEnable 9 //Display enable
#define dB4 10 //Display B7
#define dB5 11 //Display B6
#define dB6 12 //Display B5
#define dB7 13 //Display B4
// Specify the LCD
LiquidCrystal lcd(dRs, dEnable, dB4, dB5, dB6, dB7);
// Specify for testing inputs
#define TEST_INPUT A0 //for test input
int triacPot = 0; // initialize to an off condition, test only
// Specify MOC/triac pulse and counts in a 1/2 cycle of 60hz for mapping
int phaseLow = 500;
int phaseHigh = 40;
#define PULSE 4
// Specify timing
unsigned long turnDays = 420000; // 19 days in milliseconds =19*24*60*60*1000 1641600000
unsigned long dayCount = 0;
unsigned long oneDay = 108000; //86400000
unsigned long motorTime = 0; // initialize with 0; the time when the motor was turned on or off
unsigned long timeOn = 3000; // however long the motor should be on */; 15000
unsigned long timeOnError = 30000;
unsigned long timeOff = 6000;// however long the motor should be off */; 3585000
unsigned long timeOffError = 30000;
unsigned long measureTime = 0; // initialize with 0; the time when the last measurement was made
unsigned long displayTime = 0; // initialize with 0; the time when the display was last refreshed
unsigned long testTime = 0;
bool motorRunning = false; // start with the motor off
bool motorError = false;
bool heaterError = false;
bool DHTerror = false;
// Initialize DHT sensor.
#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
DHT dht(DHTPIN, DHTTYPE);
float h;
float t;
float f;
//Specify the PID
double Setpoint, Input, Output;
double Kp=18, Ki=1, Kd=1;
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
void setup(){
lcd.begin(20, 4);
lcd.clear();
dht.begin();
pinMode(TEST_INPUT, INPUT); //test purposes potentiometer
pinMode(DHTPIN, INPUT); //DHT sensor input
pinMode(DETECT, INPUT); //zero cross detect INPUT_PULLUP
pinMode(GATE, OUTPUT); //triac gate control
pinMode(motorPin, OUTPUT); //motor control
pinMode(dEnable, OUTPUT); //display
pinMode(dRs, OUTPUT); //display
pinMode(dB7, OUTPUT); //display
pinMode(dB6, OUTPUT); //display
pinMode(dB5, OUTPUT); //display
pinMode(dB4, OUTPUT); //display
// set up Timer1 ATMEGA 328 data sheet pg 134)
OCR1A = 510; //initialize the comparator to an off/low condition
TIMSK1 = 0x03; //enable comparator A and overflow interrupts
TCCR1A = 0x00; //timer control registers set for
TCCR1B = 0x00; //normal operation, timer disabled
// set up zero crossing interrupt
attachInterrupt(digitalPinToInterrupt(DETECT),zeroCrossingInterrupt, RISING); //IRQ0 is pin 2. Call on rising signal
//Set up the PID loop
//initialize the variables we're linked to
Input = 70;
Setpoint =100; // 99 to 101 F is recommended range
myPID.SetMode(AUTOMATIC);
//Interrupt Service Routines
void zeroCrossingInterrupt(){ //zero cross detect
TCCR1B=0x04; //start timer with divide by 256 input
TCNT1 = 0; //reset timer - count from zero TCNT1 is the Timer/counter Register for timer 1
ISR(TIMER1_COMPA_vect){ //comparator match
digitalWrite(GATE,HIGH); //set triac gate to high
TCNT1 = 65536-PULSE; //trigger pulse width
ISR(TIMER1_OVF_vect){ //timer1 overflow
digitalWrite(GATE,LOW); //turn off triac gate
TCCR1B = 0x00; //disable timer stopd unintended triggers
void loop(){
// manage the egg turner
unsigned long now = millis();
dayCount = millis() / oneDay;
if (millis() <= turnDays || motorRunning ==true) //enter this block only if time is less than 19 days or the motor is running
if(motorRunning)
// The motor is running.
// Is it time to turn it off?
if(now - motorTime >= timeOn)
digitalWrite(motorPin, LOW); // turn off motor
motorTime = now;
// The motor is not running.
// Is it time to turn it on?
if(now - motorTime >= timeOff)
digitalWrite(motorPin, HIGH); // turn on motor
motorTime = now;
motorRunning = true;
// Reading temperature or humidity takes about 250 milliseconds!
if(now - measureTime >= 500)
// It is time to measure temperature
h = dht.readHumidity();
//t = dht.readTemperature();
f = dht.readTemperature(true); //(isFahrenheit = true)
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f)) {
DHTerror = true;
//Serial.println("Failed to read from DHT sensor!");
return;
measureTime = now;
Input = f;
myPID.Compute();
if(now - testTime >= 20000) ///-------------------------------------------
triacPot = triacPot + 100; // analogRead(TEST_INPUT);
if(OCR1A > 499)
triacPot = 0;
OCR1A = map(triacPot,0,1023, phaseLow, phaseHigh); //map(Output,0,255, phaseLow, phaseHigh); //set the compare register brightness desired.
testTime = now;
//Send info to LCD display
if(now - displayTime >= 1000)
// lcd.clear();
//Day count
lcd.setCursor(0, 0);
lcd.print("Day: ");
lcd.print(" "); //print 2 blanks in case the number changes from 3 to 2 digits
lcd.setCursor(5, 0); //go back to the start of the number
lcd.print(dayCount);
//temperature
lcd.setCursor(0, 1);
lcd.print("Temp: ");
lcd.print(" "); //print 9 blanks in case the number changes from 3 to 2 digits
lcd.setCursor(6, 1); //go back to the start of the number
lcd.print(f);
lcd.print(" ");
lcd.print((char)223);
lcd.print("F"); // \t
//humidity
lcd.setCursor(0, 2);
lcd.print("Hum: ");
lcd.print(" "); //print 8 blanks in case the number changes from 3 to 2 digits
lcd.setCursor(5, 2); //go back to the start of the number
lcd.print(h);
lcd.print(" %");
//humidity/temperature warning
//lcd.setCursor(0, 0);
//heater percent on
lcd.setCursor(10, 0);
lcd.print("Heat: ");
lcd.print(" "); //print 3 blanks in case the number changes from 3 to 2 digits
lcd.setCursor(16, 0); //go back to the start of the number
lcd.print(OCR1A); //-phaseLow/(phaseHigh-phaseLow)); OCR1A
//Serial.println(triacPot);
//Motor on/off
lcd.setCursor(0, 3);
if(motorRunning)
lcd.print("Motor: On ");
lcd.print("Motor: Off");
//Display Millis()
lcd.setCursor(11, 3);
lcd.print(millis());
displayTime = now;
