Topic: Compile warning using SD library - unused variable (Read 1 time) previous topic - next topic
Hal_cat
Possibly not a major problem, generates noise in the compile output
but does it indicate some missing error checks?
/Applications/Arduino.app/Contents/Java/libraries/SD/src/utility/SdFile.cpp: In static member function 'static uint8_t SdFile::make83Name(const char*, uint8_t*)':
/Applications/Arduino.app/Contents/Java/libraries/SD/src/utility/SdFile.cpp:261:15: warning: unused variable 'b' [-Wunused-variable]
       uint8_t b;
from SdFile.cpp (just the function with the warning):
// format directory name field from a 8.3 name string
uint8_t SdFile::make83Name(const char* str, uint8_t* name) {
  uint8_t c;
  uint8_t n = 7;  // max index for part before dot
  uint8_t i = 0;
  // blank fill name and extension
  while (i < 11) name[i++] = ' ';
  i = 0;
  while ((c = *str++) != '\0') {
    if (c == '.') {
      if (n == 10) return false;  // only one dot allowed
      n = 10;  // max index for full 8.3 name
      i = 8;   // place for extension
      // illegal FAT characters
      uint8_t b;                                              <<<<< this is line 261 <<<<<<<<<<<<
#if defined(__AVR__)
      PGM_P p = PSTR("|<>^+=?/[];,*\"\\");
      while ((b = pgm_read_byte(p++))) if (b == c) return false;
#elif defined(__arm__)
      const uint8_t valid[] = "|<>^+=?/[];,*\"\\";
      const uint8_t *p = valid;
      while ((b = *p++)) if (b == c) return false;
#endif
      // check size and only allow ASCII printable characters
      if (i > n || c < 0X21 || c > 0X7E)return false;
      // only upper case allowed in 8.3 names - convert lower to upper
      name[i++] = c < 'a' || c > 'z' ?  c : c + ('A' - 'a');
  // must have a file name, extension is optional
  return name[0] != ' ';
Note that if neither __AVR__ nor __arm__ are defined, variable b is unused.
I am unfamiliar with the possible values that should be checked here, but the definition of b could be inside the if defined statements to eliminate the warning.
But perhaps there should be another test?
I am compiling for an Arduino 101.
IDE 1.6.16
Mac OS X 10.11.6
SD Library 1.1.1
PaulS
Quote
No. There should be an else clause.
#else
      b = b;
#endif
