Topic: [SOLVED] verification error; content mismatch (Read 44967 times) previous topic - next topic
PhiniphoeniX
Feb 07, 2017, 07:28 pm Last Edit: Feb 17, 2017, 04:13 pm by PhiniphoeniX
Hello everyone,
I've been using  the Arduino Uno R3 SMD Edition for about two months but, just now, I've encountered this issue:
avrdude: verification error, first mismatch at byte 0x0000
         0x62 != 0x0c
avrdude: verification error; content mismatch
The message appears every time I try to upload any kind of program to  the Arduino so I think it's a board problem.
If you have any suggestions or need more information please reply!
PhiniphoeniX
Ok I'll try ordering an external ISP and reburn the bootloader with it.
I'll post the result.
kprims
Thank you. Posting the results may help others with the same issue.
PhiniphoeniX
Everything solved here's what I did:
1 Ordered a USBasp from amazon (.it, url: https://www.amazon.it/gp/product/B01N2QBHG9/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1)
2 When it arrived I connected the 6-pin plug to the ICSP on the Arduino and the USB part to the computer (you have to have the Arduino connected too though)
3 I went to "Tools>Programmer" and selected "USBasp", then "Tools>Burn the bootloader"
4 I verified and uploaded "Blink"
5 Enjoy  :D
Archut
yeah so i am too encountering the same problem with the error code
Code: [Select]
Arduino: 1.6.12 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 4,420 bytes (13%) of program storage space. Maximum is 32,256 bytes.
Global variables use 483 bytes (23%) of dynamic memory, leaving 1,565 bytes for local variables. Maximum is 2,048 bytes.
avrdude: verification error, first mismatch at byte 0x0042
         0xc2 != 0xe2
option enabled in File -> Preferences.
this error started appearing when the battery was short circuited unintentionally around 2-3 times for a very short period of 1 sec max
this happened when the atmega was out of the arduino on a breadboard without any short circuit protection.
Though i am able to burn boot loader using another uno i have the problem still persists though the rx and tx lights blink as they used to do
Need arises Ideas.Thinking is the first step to Invention.
Questioning leads Discovery.
VirajAnand
This Means I can upload the program using other boad to the ATmega???
flyingraccoons2
could I just buy a new microprossesor because I'm getting the same problem
