Topic: IF  with AND and OR fuctions (Read 281317 times) previous topic - next topic
sathopper
With my BASIC language programmed controllers I can use AND and OR.
example:  IF (VAL > 100 AND VAL < 140) THEN ...
How can I solve this with the if function in the Arduino?
Thanks.  ;)
robtillaart
you need to add () 's and a lot of them , further Arduino knows 2 types of AND and OR's the logical and the bitwise.
Quote
becomes
Code: [Select]
if ((val > 100) && (val < 140))
See for more information http://www.arduino.cc/en/Reference/Boolean
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
lloyddean
#2
Dec 02, 2010, 06:06 pm Last Edit: Dec 02, 2010, 11:38 pm by lloyddean Reason: 1
C++ Keyword Synonyms
Code: [Select]
and             &&
and_eq          &=
bitand          &
bitor           |
not             !
not_eq          !=
or              ||
or_eq           |=
xor             ^
xor_eq          ^=
EDIT:  What the above means is that:
Code: [Select]
can be written as:
Code: [Select]
if ( val > 100 and val < 140 )
sathopper
Quote
Thanks for this link didn't now where to look.
It works perfect now. Many thanks :) :) :)
foxbat
Quote
Why? && and || are of a much lower precedence than any operator you would commonly use in a comparative expression. Overbracketing just leads to parenthesis-blindness in my opinion, though I concede that is partly a matter of style.
robtillaart
Quote
True, but for those few times the precedence was higher it kept my debugging sessions short except the first time :)
Quote
Ever debugged LISP code?
Rob Tillaart
