Post the code you're having problems with and the error messages you're seeing.
I rather thought I had done as you suggest?
The compiler is highlighting the fourth line down.
I can't see how to copy the actual error message in orange. How is this done?
The full code
is
//set up the global variables
const int numReadings = 10;
const int numPorts = 2;
long numberofReadings=numReadings;
int readings[numReadings][numPorts]; // the readings from the analog input ports
int readIndex[numPorts];// the index of the current reading
float total[numPorts]; // the running totals for each port
float average[numPorts]; // the average for each port
// initialize serial:
analogReference(EXTERNAL);
InitArray(readings,numReadings,numPorts); //call function to pre-fill the arrays
average= GetNewAverage(readings, numReadings,numPorts);
// send it to the computer as ASCII digits
Serial.print(average);
Serial.print(" ");
delay(1000); // delay in between reads for stability
Serial.println(" ");
void InitArray(int readings[][],int nubReadings, int numPorts){
// initialize all the readings to an initial read value from each port
for (int j=0; j< numPorts; j++){
int initReading=analogRead(j);
for (int i = 0; i < numReadings; i++) readings[i][j] = initReading;
total[j]=numberofReadings*initReading;
average[j]=initReading;
float GetNewAverage(int readings[][], int numReadings, int numPorts){
for (int j=0;j<numPorts; j++){
// subtract the last reading:
total = total - readings[readIndex][j];
// read from the sensor:
readings[readIndex][j] = analogRead(j);
// add the reading to the total:
total = total + readings[readIndex][j];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
and the error messages are:
Func7_2_dimensional_array:7: error: declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first
Func7_2_dimensional_array:8: error: declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first
Func7_2_dimensional_array.ino: In function 'void setup()':
Func7_2_dimensional_array:19: error: invalid conversion from 'int (*)[2]' to 'int'
Func7_2_dimensional_array:7: error: too many arguments to function 'void InitArray(int, int)'
Func7_2_dimensional_array:19: error: at this point in file
Func7_2_dimensional_array.ino: In function 'void loop()':
Func7_2_dimensional_array:23: error: invalid conversion from 'int (*)[2]' to 'int'
Func7_2_dimensional_array:8: error: too many arguments to function 'float GetNewAverage(int, int)'
Func7_2_dimensional_array:23: error: at this point in file
Func7_2_dimensional_array:23: error: incompatible types in assignment of 'float' to 'float [2]'
Func7_2_dimensional_array:25: error: call of overloaded 'print(float [2])' is ambiguous
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:58: note: candidates are: size_t Print::print(char) <near match>
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:59: note: size_t Print::print(unsigned char, int) <near match>
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:60: note: size_t Print::print(int, int) <near match>
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:61: note: size_t Print::print(unsigned int, int) <near match>
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:62: note: size_t Print::print(long int, int) <near match>
C:\Documents and Settings\RCM\Desktop\Calorimeter development environment\arduino-1.0.5\hardware\arduino\cores\arduino/Print.h:63: note: size_t Print::print(long unsigned int, int) <near match>
Func7_2_dimensional_array.ino: At global scope:
Func7_2_dimensional_array:30: error: declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first
Func7_2_dimensional_array:39: error: declaration of 'readings' as multidimensional array must have bounds for all dimensions except the first
Func7_2_dimensional_array.ino: In function 'float GetNewAverage(int, int)':
Func7_2_dimensional_array:42: error: invalid types 'int [10][2][int [2]]' for array subscript
Func7_2_dimensional_array:44: error: invalid types 'int [10][2][int [2]]' for array subscript
Func7_2_dimensional_array:46: error: invalid types 'int [10][2][int [2]]' for array subscript
Func7_2_dimensional_array:48: error: incompatible types in assignment of 'int*' to 'int [2]'
Func7_2_dimensional_array:50: error: ISO C++ forbids comparison between pointer and integer
Func7_2_dimensional_array:52: error: incompatible types in assignment of 'int' to 'int [2]'
