Topic: Arduino Due Windows 7 64bit drivers non working (Read 6396 times) previous topic - next topic
attiliovolpe
#15
Feb 15, 2017, 07:14 pm Last Edit: Feb 15, 2017, 07:40 pm by attiliovolpe
I don't have any USB3.0 port on the PC, the cable is the cable already working with my tablet often connected to the same pc for download/upload of some files.
Right now I tried two other different devices, Mega 2560 and Nano, it are working properly; the problem is coming from the unsigned drivers
attiliovolpe
"Going to refer you back to my FIRST POST.
And HERE and HERE and HERE."
Also following the proposed solutions in the links nothing to do, I tried all!
Only one is good, press F8 during the windows booting and then disable the signature checjing for the drivers, but this one is temporary, have to be done time by time.
We will see in the future!
ballscrewbob
#17
Feb 15, 2017, 09:42 pm Last Edit: Feb 16, 2017, 02:55 am by Ballscrewbob
The Temporary one as so so call it does NOT have to be run every time.
It is a one off to get the driver in after which I have NEVER seen it need doing again for that particular piece of hardware or software..
I am starting to think its a waste of my time on this and that any real effort is being wasted I am sorry to say.
However you are now in the correct section of the forum so read away to your hearts content.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
ballscrewbob
I have just read the whole thread again and it is like there is something missing that we have not been told to be able to make a proper diagnosis.
What does "I've another issue but we'll see later" mean ? what issue ?
I am going to refer you to this post and I would like you to take in as much as you can so that you can understand how hard it is to deal with things when you don't have ALL the information.
attiliovolpe
This one is something else referred to the IDE, but I solved it as you can see on the Italian forum.
"The Temporary one as so so call it does NOT have to be run every time.
It is a one off to get the driver in after which I have NEVER seen it need doing again for that particular piece of hardware or software.."
Disabling the Driver Signature Checking on the boot menĂ¹ pressing F8 doesn't take any permanent effect and you can try it; this one is permitted in order to allo the developers to test the drivers before having the Microsoft certification.
So the purposes of this thread are:
1- inform the Arduino's team about the uncertificated driver;
2- inform everybody about the trouble hoping who somebody else have already found the same proble and can give some helping;
3- looking for some solution in order to have the best way to work with Arduino and the IDE.
"I am starting to think its a waste of my time on this and that any real effort is being wasted I am sorry to say."
I don't write here on the forum looking for ready made solution doing nothing by myself, before coming here on the forum I spent  long time looking for a solution on the web, so if you think are loosing your time, I'm sorry for that and I really thanks  you, but you are free to don't replay.
eivan7538
#20
Apr 01, 2018, 04:43 pm Last Edit: Apr 01, 2018, 04:49 pm by eivan7538
I have the same problem. It seems like this issue has not been resolved, the driver for Due will not install. Is there any workaround?
I have Windows 10 and have been using Uno with no issues whatsoever. Yesterday I got Due. My IDE is most rescent 1.8.5 and I installed the SAM boards package in Boards Manager. Then from Windows Device manager I tried to install the "Arduino Due Programming Port" driver from C:\Program Files (x86)\Arduino\drivers\Arduino.inf. The app tries to install the driver but then gives the error message "This device can not start (Code 10)". The "Arduino Due Programming Port" in the device manager now has a yellow triangle and the IDE can not communicate with it and upload any FW.
I turned my anivirus off and tried both USB2 and USB3 ports. Nothing works. Any help please?
ard_newbie
#21
Apr 01, 2018, 05:16 pm Last Edit: Apr 01, 2018, 05:20 pm by ard_newbie
The last topic I have seen with an upload issue with Windows ( Windows 10)  was in fact a USB cable issue. I don't pretend it is the exact same issue but it could be Worth trying:
https://forum.arduino.cc/index.php?topic=505238.0
Usually when an upload can't be performed, the first remedy to try is pushing the erase button for 3 seconds, then the reset button for 3 seconds, then select the correct COM port.
And this one thread, reply #2:
https://forum.arduino.cc/index.php?topic=344879.0
eivan7538
Yes, tried different cable and it works, blinky is flashing! Thanks a lot!
I have 3 mini USB cables and only one of them works with Due. Need to be careful with those USB cables, it's confusing.
attiliovolpe
Good morning, I still have the same problem and there is no way to fix it till now!
So if somebody else has some suggestion, please post it here.
