Topic: simple h-bridge tank (Read 804 times) previous topic - next topic
nikola50
Ok, first of all, i must tell that im total noob when it comes to programming, this is my first attempt to do anything. I modified bluetooth led on-off code to run 2 motors trough h-bridge. I want that because i want to remote controll tank trough bluetooth module. I know its not big problem, its just some command witch i dont know, but i would like if someone of more expirienced programmers would like to help me with this. Whole code is supposed to work like "i pressed button on mobile phone-arduino do theese commands, i let button, arduino stops". Its really simple, but for me, as a noob, its not. Problem is that motors are running only when i send command "a" and "c", and all other commands are not working. Also, problem is that all thoose commands are working constantly, they are not stopping when i let button. If its possible, i would also like help with that.
AWOL
Code: [Select]
char junk;
String inputString="";
void setup()                    // run once, when the sketch starts
 Serial.begin(9600);            // set the baud rate to 9600, same should be of your Serial Monitor
 pinMode(3, OUTPUT);//motor1 pin1
 pinMode(4, OUTPUT);//motor1 pin2
 pinMode(5, OUTPUT);//motor2 pin1
 pinMode(6, OUTPUT);//motor2 pin2
  if(Serial.available()){
  while(Serial.available())
      char inChar = (char)Serial.read(); //read the input
      inputString += inChar;        //make a string of the characters coming on serial
    Serial.println(inputString);
    while (Serial.available() > 0)
    { junk = Serial.read() ; }      // clear the serial buffer
    if(inputString == "a"){         //going foward, both motors
      digitalWrite(3, HIGH);
      digitalWrite(4, LOW);
      digitalWrite(5, HIGH);
      digitalWrite(6, LOW);
      (inputString == "d");    //going backward, both motors
      digitalWrite(3, LOW);
      digitalWrite(4, HIGH);
      digitalWrite(5, LOW);
      digitalWrite(6, HIGH);
     (inputString == "b");    //going left
      (inputString == "c");    //going right
     digitalWrite(6, LOW);}
     else if(inputString == "e");   //turn off motors
    inputString = "";
AWOL
Code: [Select]
Can you explain that line, please?
nikola50
well, as i said, im total noob about this. I hoped that it will do that set of commands if i send that letter trough phone. Fortunately, i found finished code for my project, so im good, but i reeaaally need to learn how to program arduino
