Topic: MKR1000 won't stay connected (Read 693 times) previous topic - next topic
lvincek
Hi.
My MKR1000 connects and disconnects whenever I try to upload or turn on the serial monitor.  Usually, I cannot load a program to it.  If it successfully load the program, and try to open the serial monitor, that will fail.
Picture below shows the 'blink led' program failing to load, even thought the COM port is found and the board is properly selected.  Any ideas?  I had this problem right out of the box.  Never got it to work.
ballscrewbob
Couple of things wrong with this post.
No picture
Wrong area
PS dont post pictures or errors use CODE TAGS ( </> )
They let you post a lot more of the error messages that a picture will and besides the forum has quite a low picture size limit.
Lets see about getting this moved to the correct place.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
