Topic: How can i measure pulse width? (2 interrupts) (Read 21435 times) previous topic - next topic
rukez
I need to measure pulse width (not time between two pulses, but length of one single pulse - from raising to falling) on fuel injector - it is driven by simple square pulse on ground wire (positive wire is allways attached to battery's +)
Can i assign TWO interrupts to ONE pin? i tried this:
Code: [Select]
int injPin = 3; //Pin connected to injector's ground wire
volatile unsigned long injTime1;  //Time of front raising
volatile unsigned long injTime2;  //Time of front falling
unsigned long injTime;
 pinMode(injPin, INPUT);
 digitalWrite (injPin, HIGH);  //Pull-up pin - as our injector is driven by connecting it to ground, i suppose i need to pull-up pin to get it's value as 1 when injector is turned off
 attachInterrupt(1, up, RAISING);  //interrupt on raising front
 attachInterrupt(1, down, FALLING);  //interrupt on falling front
//some code
void down()
injTime1 = micros(); //get time of pulse going down
void up()
 injTime2 = micros();  //get time of pulse going up
 injTime = injTime2 - injTime1;  //measure time between down and up (so it will be time between ground appearing ot pulled-up pin, and ground disappearing)
but my "down" (on falling) interrupt didn't fired even when i removed pull-up - can i use 2 interrupts on 1 pin, or i need to shortcut another interrupt-enabled pin (pin 2 to pin 3) and use two pins for two interrupts?
maybe someone will purpose some simple external logic to measure pulse width?
thanks!  :)
Coding Badly
As you've discovered, two interrupt conditions cannot be attached to one pin.  Instead, use a CHANGE interrupt and simply check the condition of the pin in your interrupt service routine.
rukez
Oups  :-[
Thanks a lot!
So looks like i need this:
Code: [Select]
 attachInterrupt(1, pik, CHANGE);  //interrupt on front changing
//some code
void pik()
if (injPin == LOW) //Or i need to digitalRead it first?
hope it will work, will try it in a couple of days  8-)
Coding Badly
Code: [Select]
[glow]volatile [/glow]unsigned long injTime; [glow]// When accessing this in setup or loop (or anything called by either) interrupts must be disabled[/glow]
//some code
void pik()
[glow]unsigned long injTime1;  //Time of front raising[/glow]
[glow]unsigned long injTime2;  //Time of front falling[/glow]
[glow]if ( digitalRead( injPin ) == LOW ) //Or i need to digitalRead it first? YES.[/glow]
rukez
