Topic: Arduino and Railway Modelling (Read 6888 times) previous topic - next topic
johnbet
Thank you I will try and let you know.
johnbet
Hi
When compiling the sketch I am getting the following error message.
Arduino: 1.8.1 (Mac OS X), Board: "Arduino/Genuino Uno"
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
GrooveFlotilla
Is that all the error? Did you scroll back?
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
johnbet
Hi - i jumped too soon - just tried again more slowly and yes it works fine.
I assume I can adjust the rate of the fade?
If you could dome a flicker on as in a fluorescent light that would be fantastic.
Once again thank you very much for you patience.
Regards
John
PaulRB
#19
Mar 06, 2017, 05:51 pm Last Edit: Mar 06, 2017, 05:55 pm by PaulRB
Hi John, glad it worked OK. Yes you can adjust the speed of the fade. That "10" figure controls it. The higher the number, the slower the fade.
I will have a think about a good way to simulate the flourescent light. Should it flicker for ever, like a faulty tube, or be on steady after a few seconds?
johnbet
Hi
Just a random flicker for two to fours seconds and then on steady.
PaulRB
OK, I put the random flicker on DCC F8:
Code: [Select]
// DCC Function Decoder
// Author: Ruud Boer - September 2015
// This sketch turns an Arduino into a DCC function decoder for F0 - F12
// Output pins used: 3-19 (14-19 = A0-A5)
// The DCC signal is optically separated and fed to pin 2 (=Interrupt 0).
// Optocoupler schematics: www.rudysmodelrailway.wordpress.com/software
// Many thanks to www.mynabay.com for publishing their DCC monitor and -decoder code.
// IMPORTANT: GOTO lines 15 - 28 to configure some data!
int decoderAddress = 1830; // This is the decoder address, change into the number you want.
#define F0_pin 13 // Define the output pin for every Function number in use
#define F1_pin 14 // Available pin numbers: 3 - 19
#define F2_pin 15
#define F3_pin 16
#define F4_pin 17
#define F5_pin 18
#define F6_pin 19
#define F7_pin 3
#define F8_pin 4
#define F9_pin 5
#define F10_pin 6
#define F11_pin 7
#define F12_pin 8
/* F13-F28 commented out
  #define F13_pin 0
  #define F14_pin 0
  #define F15_pin 0
  #define F16_pin 0
  #define F17_pin 0
  #define F18_pin 0
  #define F19_pin 0
  #define F20_pin 0
  #define F21_pin 0
  #define F22_pin 0
  #define F23_pin 0
  #define F24_pin 0
#include <DCC_Decoder.h>                      // Comment for 123d Test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#define kDCC_INTERRUPT 0
byte Func[4]; // 0=L F4-F1, 1=F9-F5, 2=F12-F9, 3=F20-F13, 4=F28-F21
byte instrByte1;
int Address;
boolean RawPacket_Handler(byte pktByteCount, byte* dccPacket) {
  Address = 0;
  if (!bitRead(dccPacket[0], 7)) { //bit7=0 -> Loc Decoder Short Address
    Address = dccPacket[0];
    instrByte1 = dccPacket[1];
  else if (bitRead(dccPacket[0], 6)) { //bit7=1 AND bit6=1 -> Loc Decoder Long Address
    Address = 256 * (dccPacket[0] & B00000111) + dccPacket[1];
    instrByte1 = dccPacket[2];
  if (Address == decoderAddress) {
    byte instructionType = instrByte1 >> 5;
    switch (instructionType) {
      case 4: // Loc Function L-4-3-2-1
        Func[0] = instrByte1 & B00011111;
      case 5: // Loc Function 8-7-6-5
        if (bitRead(instrByte1, 4)) {
          Func[1] = instrByte1 & B00001111;
        else { // Loc Function 12-11-10-9
          Func[2] = instrByte1 & B00001111;
          case 6: // Future Expansions
          switch (instrByte1&B00011111) {
            case B00011110: // Loc Function F13-F20
              Func[3]=dccPacket[pktByteCount-1];
            case B00011111: // Loc Function F21-F28
              Func[4]=dccPacket[pktByteCount-1];
    if (Func[0]&B00010000) digitalWrite(F0_pin, HIGH); else digitalWrite(F0_pin, LOW);
    if (Func[0]&B00000001) digitalWrite(F1_pin, HIGH); else digitalWrite(F1_pin, LOW);
    if (Func[0]&B00000010) digitalWrite(F2_pin, HIGH); else digitalWrite(F2_pin, LOW);
    if (Func[0]&B00000100) digitalWrite(F3_pin, HIGH); else digitalWrite(F3_pin, LOW);
    if (Func[0]&B00001000) digitalWrite(F4_pin, HIGH); else digitalWrite(F4_pin, LOW);
    if (Func[1]&B00000001) digitalWrite(F5_pin, HIGH); else digitalWrite(F5_pin, LOW);
    if (Func[1]&B00000010) digitalWrite(F6_pin, HIGH); else digitalWrite(F6_pin, LOW);
    //if (Func[1]&B00000100) digitalWrite(F7_pin,HIGH); else digitalWrite(F7_pin,LOW);
    //if (Func[1]&B00001000) digitalWrite(F8_pin, HIGH); else digitalWrite(F8_pin, LOW);
    if (Func[2]&B00000001) digitalWrite(F9_pin, HIGH); else digitalWrite(F9_pin, LOW);
    if (Func[2]&B00000010) digitalWrite(F10_pin, HIGH); else digitalWrite(F10_pin, LOW);
    if (Func[2]&B00000100) digitalWrite(F11_pin, HIGH); else digitalWrite(F11_pin, LOW);
    if (Func[2]&B00001000) digitalWrite(F12_pin, HIGH); else digitalWrite(F12_pin, LOW);
    /*//Print DCC packet bytes for testing purposes
      for (byte n=0; n<5; n++) {
      Serial.print(Func[n],BIN);
      Serial.print(" ");
      Serial.println(" ");
void fadeF7() {
  static unsigned long lastFadeTimeF7 = 0;
  static int fadeLevelF7 = 0;
  if (millis() - lastFadeTimeF7 > 10) {
    lastFadeTimeF7 = millis();
    if (Func[1]&B00000100) {
      if (fadeLevelF7 < 255) analogWrite(F7_pin, ++fadeLevelF7);
    else {
      if (fadeLevelF7 > 0) analogWrite(F7_pin, --fadeLevelF7);
void flickerF8() {
  static unsigned long startTimeF8 = 0;
  static unsigned long lastFlickerF8 = 0;
  static int stateF8 = HIGH;
  if (Func[1]&B00001000) {
    if (stateF8 == LOW) {
      startTimeF8 = millis();
      stateF8 = HIGH;
    else {
      if (millis() - startTimeF8 > 3000) {
        digitalWrite(F7_pin, HIGH);
      else {
        if (millis() - lastFlickerF8 > 25) {
          lastFlickerF8 = millis();
          if (random(2) == 0) digitalWrite(F7_pin, HIGH); else digitalWrite(F7_pin, LOW);
  else {
    stateF8 = LOW;
  Serial.begin(38400);
  DCC.SetRawPacketHandler(RawPacket_Handler); // Comment for 123d Test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  DCC.SetupMonitor( kDCC_INTERRUPT );         // Comment for 123d Test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  for (byte n = 3; n < 20; n++) pinMode(n, OUTPUT);
  DCC.loop();   // Comment for 123d Test !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  fadeF7();
  flickerF8();
johnbet
Thanks - will give it a try.
Regards
John
johnbet
Hi the Flicker works but on Pin 3 with F8
The fade doesn't work at all now - but that may be as you intended.
Could I make the fade work on Pin 3 and the flicker on pin 4?
Regards
John
PaulRB
#24
Mar 07, 2017, 05:51 pm Last Edit: Mar 07, 2017, 05:53 pm by PaulRB
Oops, my bad.
In flickerF7() I put:
Code: [Select]
 else {
    stateF8 = LOW;
That should be F8_pin not F7_pin.
I want you to read and understand the code changes I am making. If you had been there is a chance you would have spotted my mistake. Ask me any questions you have about how the changes I made work.
johnbet
Hi
I did wonder why there was reference to F7 in the Flicker Code - I will edit the code and try again.
Thank you?
johnbet
I have now amended the code as follows
void fadeF7() {
    else {
void flickerF8() {
      stateF8 = HIGH;
    else {
      else {
          if (random(2) == 0) digitalWrite(F8_pin, HIGH); else digitalWrite(F8_pin, LOW);
  else {
    stateF8 = LOW;
Will now give it a try.
Thanks again for your help.
PaulRB
#27
Mar 08, 2017, 08:05 pm Last Edit: Mar 08, 2017, 08:15 pm by PaulRB
Did you forget how to use code tags?
What else did you change, apart from that correction I suggested?
johnbet
I changed any reference to F7 to F8 in the flicker routine.
I have to apologise I don't know what code tags are?
Regards
John
GrooveFlotilla
Code tags are explained in the "How to use this forum - please read" sticky, the first thread at the top of this section of the forum
