Topic: HC-05 setup and configuration with the MKRZero (Read 2660 times) previous topic - next topic
OMDavidson
So I'm very new to all of this, but have a little experience with C+ so I don't know NOTHING...
Anyway, I've just bought a MKRZero and a HC-05 bluetooth module and I'm trying to use the serial monitor to change things like the name of the module etc.
I've found a few tutorials on how to put the module into AT command mode, however I keep running into a problem with the "SoftwareSerial" library in that it apparently doesn't support the MKRZero processor?
Can anyone assist?
Google isn't helping me right now and I'm essentially clueless
Thanks!
MarkDerbyshire
#1
Mar 04, 2017, 10:52 am Last Edit: Mar 04, 2017, 10:58 am by MarkDerbyshire
SoftwareSerial doesn't work with the MKR1000 or the MKRZero untill someone rewrites the library.  There is another Serial port - Serial1 on pins 14 & 13.  You can also program your own extra Serial ports
https://learn.adafruit.com/using-atsamd21-sercom-to-add-more-spi-i2c-serial-ports/overview
