Topic: array initialization discrepancy? (Read 1 time) previous topic - next topic
jamie
Feb 13, 2007, 04:22 am Last Edit: Feb 13, 2007, 04:25 am by jamie Reason: 1
hi all!
i've been trying to initialize a an array of chars, and i've noticed something weird.  it seems as if i'm getting an extra character when i initialize the array one way versus another.
i.e.: when i initialize
Code: [Select]
char serTest[2]={'O','K'};
it's equivalent to this (it's adding the carriage return)
Code: [Select]
serTest[0]='O';
serTest[1]='K';
serTest[2]=13;
when i call
Code: [Select]
Serial.print(serTest);
just me?  on purpose?  what?
lub,
j
kg4wsv
Calling Serial.print with a type of char * expects a null terminated string.  Your array is not a normal null terminated string, so the function is traipsing off into memory printing stuff beyond the end of your array until it finds a null.
If you are using it as a string, your array should be initialized as
Code: [Select]
char serTest[3] = { 'o', 'k', '\0'};
or
Code: [Select]
char serTest[] = "ok";
These are identical initializations.
-j
