Topic: LOFI Blocks - Mobile app to control and program Arduino robot on Android and iOS (Read 4653 times) previous topic - next topic
LoFiRobot
Hello everyone,
We have just published a new app with an attempt to simplify robotics education for kids.
LOFI Blocks provides simple visual programming interface based on Google Blockly and Scratch for programming robots built with Arduino.
The app is available on iOS and Android and communicates with Arduino over bluetooth modules such as most popular HC-05, HC-06 and HM-10 BLE module on iOS.
You can find more info about the app, arduino code and build instructions on LOFI Blocks website
You can find the app here:
Android version
iOS version
below is some more press info.
LOFI Blocks is an app and a robot recipe that will help you learn (or teach others!) how to control ROBOTS
By snapping colorful blocks you will learn principles of programming and code your robot to avoid obstacles, follow light and do plenty of other things.
HOW TO GET THE ROBOT?
BUILD IT YOURSELF! - if you have an Arduino board together with some basic electronic components you can make a DIY version of LOFI Robot from our recipe that will work with LOFI Blocks app.
GET OUR KIT - if you would like to have an all-inclusive package with all the parts needed to build the robot and user friendly LOFI Brain controller order our LOFI Robot - EDUBOX kit.
WHAT IS ON BOARD?
Simple interface for visual programming - based on Google Blockly, similar to Scratch.
Connects with LOFI Robot or any other Arduino based robot.
Blocks for controlling two DC motors, four analog inputs, four analog outputs (PWM or servo), distance sensor and buzzer.
Built in gamepad and accelerometer to control your robot.
Built in inputs monitor and a basic console to simplify debuging
CONFIGURATION
Build a robot form LOFI Robot EDUBOX kit or DIY Arduino version
If you are using Android pair your device with bluetooth module. If you are using iOS pairing is not necessary.
Upload LOFI Robot firmware to your LOFI Brain controller or other Arduino that tyou are using.
Install LOFI Blocks app on your device.
Lounch the app and click robot head icon in the top-right corner, connection panel will appear with list of available robots that you can connect to.
If the app connects properly with the robot a round outline wiil appear on the robot head icon.
You can start to code!
AVAILABLE VERSIONS
Android - min. Android 4.0
iOS - min. iPad3 or iPhone5
Online - works on Chrome (in progress)
Ofline - Windows and Mac OSX (in progress)
LOFI ROBOT FIRMWARE - FOR LOFI BRAIN CONTROLLER
You can find firmware for Arduino Leonardo in our DIY recipe page.
BEWARE ;-)
LOFI Blocks is in public beta. Please send us any comments and feedback on HALO@LOFIROBOT.COM
WHAT WE ARE WORKING ON:
Bluetooth 4.0 support on Android
Compass suport
Adding RANDOM NUMBER and MAP TO RANGE blocks
Translate to more languages
JUNIOR version - with icons instead of text commands
HELP US TRANSLATE LOFI BLOCKS!
If you would like to have the app in your language please help us with translation. It takes about 15 minutes to translate basic commands. Write us on HALO@LOFIROBOT.COM for details.
wallacemalheiros
Could you please send the details of how the app format the data sent through the bluetooth?
