Topic: Problem with Serial on Arduino Pro 328 3.3V 8MHz (Read 12705 times) previous topic - next topic
bhagman
Forgot to mention, if you're interested (doesn't seem like many people are), I've also proposed a change to the underlying SerialComm class that allows a bit of help on input (i.e. readnumber() etc. instead of bashing your own each and every time).
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1245549766
It also helps with development of other interfaces.  I'd appreciate some thoughts.
b
http://wiring.org.co/ - Wiring - Where Arduino came from. (Wiring begat Arduino)
http://loftypremises.com/ - Everything you wanted to know about me.... and less
http://roguerobotics.com/ - #1 Canadian Arduino distributor
EmilyJane
I'm having a hard time with the new source files I created by pasting from your post. They seem to contain lots of '\240' and '\302' characters that BBEdit can't seem to see. Any suggestions?
bhagman
#17
Jun 25, 2009, 08:16 pm Last Edit: Jun 25, 2009, 10:50 pm by bhagman Reason: 1
Hmm... strange.  I've uploaded the two files here:
http://www.mediafire.com/Arduino
b
EmilyJane
Thank you. Works like a hose.
I'm glad that mystery is solved.
jordi
Today i was testing a prototype using 328 and 8MHZ. I was pulling my hairs!!! I quickly realize that was a problem in the bootloader. Anyway i google "Arduino Bootloader 328 8mhz problem" and i've found this.
I tried the solutions and works great now!!
Thanks!  :)
svoisen
Fix worked for me as well. Thanks for remedying my frustration. I hope this fix makes it into the next version of the IDE.
agitar
Actually, I thougth, I was using a 16 MHz with 5 Volt. This is, what was said to me. I looked at the FTDI, it is marked with 3.3Volt. Does it determine 8 MHz? I can't read what's written on the crystal.
Something, what could perhaps help you. Everything runs perfect, if I compile with Arduino Duemilanove with 328.
friarbayliff
I was having this same problem.  I copied over the code posted by bhagman and it worked perfectly. Thanks to you all for the great fix - especially EJ, who intercepted my thread about the same problem and sent me to this one.
Thanks!
