Topic: Catrina bootloader not working with Windows 7 (Read 968 times) previous topic - next topic
claudea2
Hello,
I am developing a board that uses an ATmega32U4. I have re-compiled the Catrina bootloader to change my VID and PID and change the operating frequency to 8Mhz. Everything works fine on a Mac and on a PC running Windows 10 but the bootloader hangs on a PC running Windows 7. I get the following message:
Code: [Select]
Arduino: 1.8.2 (Windows 7), Board: "Mobillyo"
Forcing reset using 1200bps open/close on port COM51
PORTS {COM51, } / {} => {}
PORTS {} / {COM51, } => {COM51, }
Found upload port: COM51
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM51 -b19200 -D -Uflash:w:C:\Users\Seenov1\AppData\Local\Temp\arduino_build_137324/Master_I2C_send_Leonardo.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM51
         Using Programmer              : avr109
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: ser_send(): write error: sorry no info avail
avrdude: butterfly_recv(): programmer is not responding
The complete error message is attached as are the .inf  and the boards.txt files.
I have tried to recompile the bootloader it did not help.
A leonardo works fine. So it is not the arduino code.
The port gets disabled during the loading sequence, I have to disable it and re enable it in the device manager. Once the code is loaded with the mac, it runs in the board connected to a win 7 PC, sending messages to the serial port monitor.
I have noticed a few things: Lufa is quite old, the curent version is 151115
Has anyone tried a current LUFA release?
In the Arduino.inf file there are 2 entries for the leonardo with 2 different PIDs, 0036 and 8036 but only on entry in the catrina bootloader 0036:
Code: [Select]
%leonardo.bootloader.name%=DriverInstall, USB\VID_2341&PID_0036
%leonardo.sketch.name%=DriverInstall, USB\VID_2341&PID_8036&MI_00
Is my problem the win 7 driver?, the inf? or the the boot loader?
Any help is greatly appreciated.
