Topic: Cant upload any sketch to new Arduino Micro (Read 1 time) previous topic - next topic
XPModder
I have some kind of problem with my new Arduino micro. When I try to upload any sketch (ive tried many different ones) the compiling of the sketch works fine, but when it starts uploading to the arduino my computer makes the sound, you get when a device is unplugged and after about a minute of uploading it failes. When I got the same problem again I enabled the advanced logging and that shows that for some reason the programmer of the Arduino is not responding at all.
Code: [Select]
Arduino: 1.8.1 (Windows 10), Board: "Arduino/Genuino Micro"
Der Sketch verwendet 6402 Bytes (22%) des Programmspeicherplatzes. Das Maximum sind 28672 Bytes.
Globale Variablen verwenden 230 Bytes (8%) des dynamischen Speichers, 2330 Bytes für lokale Variablen verbleiben. Das Maximum sind 2560 Bytes.
Erzwinge Reset durch öffnen/schließen mit 1200 bps auf dem Port COM8
PORTS {COM1, COM8, } / {COM1, } => {}
PORTS {COM1, } / {COM1, COM8, } => {COM8, }
Found upload port: COM8
D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM8 -b57600 -D -Uflash:w:C:\Users\FLORIA~1\AppData\Local\Temp\arduino_build_295320/Gamepad-Test.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "D:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
Thats all the IDE shows.
It cant be a problem with the sketch itself, because Im also getting this error when uploading a sketch that runs perfectly fine on my arduino uno.
I dont know where this problem is coming from and how to solve it.
XPModder
Update: Since Ive written the post above ive tried many different things: Uploading all kinds of different sketches and I even tried flashing the Bootloader using my Uno and the Arduino ISP sketch, but that didnt work either. It just fails and says that it couldnt burn the bootloader. I would guess that the arduino is damaged somehow, but since its completely new and Im getting this problem since uploading the very first sketch to the same Arduino I would think that it doesnt make sence... I dont think that they sell broken or damaged Arduinos...
sterretje
Not sure if this helps: https://www.arduino.cc/en/Guide/ArduinoLeonardoMicro
There is a section Uploading Code to the Leonardo, Leonardo ETH and Micro
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
mattygio
I am having the exact same problem. I have a brand new Micro running on MacOS 10.12.3. My arduino IDE version is 1.8.2. I am receiving this error:
Code: [Select]
