Can't verify Blink (and other Sketches)
After a pause I connected my Due to the computer and tried some programming. But I can't even verify Blink. I have installed Due to the 1.8.2 IDE with the Boards Manager. And restarted the IDE.
Arduino: 1.8.2 (Windows 7), Board: "Arduino Due (Native USB Port)"
Board arduino_due_x (platform sam, package arduino) is unknown
Error compiling for board Arduino Due (Native USB Port).
Something simple probably, but not when you don't know it.
Tools > Board > Boards Manager
Install "Arduino SAM Boards", currently version 1.6.11.
Yesterday the boad version was 1.6.08, today it is 1.6.10.
I updated the tool, but I still got the same error.
When I try to Verify any sketch, my own, or Blink example, I get the following:
Arduino: 1.8.2 (Windows 7), Board: "Arduino Due (Programming Port)"
Board arduino_due_x_dbg (platform sam, package arduino) is unknown
Error compiling for board Arduino Due (Programming Port).
option enabled in File -> Preferences.
I have updated Board info in Tools//Board manager. It is now 1.6.10.
I have posted this on the DUE forum also.
Typically this error is caused by a Boards Manager update of the hardware package not completely removing the previous package version. Try this:
  • Click on the link at the line following File > Preferences > More preferences can be edited directly in the file. This should open the Arduino15 folder in Windows Explorer.
  • Navigate to ...Arduino15\packages\arduino\hardware\sam\
  • You should see two different version folders, probably 1.6.8 and 1.6.10. Delete the folder with the older version number.
  • Restart the Arduino IDE if it's running.
I've responded in your other thread:
http://forum.arduino.cc/index.php?topic=466359
@LMI, do not cross-post. Threads merged.
I did what pert said and made some progress. I got a new error message:
arm-none-eabi-g++: error: CreateProcess: No such file or directory
exit status 1
LMI:
Do that and then post the output as you did before.
Hi. I got this:
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\LM7\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\LM7\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\LM7\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -ide-version=10802 -build-path C:\Users\LM7\AppData\Local\Temp\arduino_build_257890 -warnings=default -build-cache C:\Users\LM7\AppData\Local\Temp\arduino_cache_399328 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Program Files\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\LM7\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\LM7\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\LM7\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -ide-version=10802 -build-path C:\Users\LM7\AppData\Local\Temp\arduino_build_257890 -warnings=default -build-cache C:\Users\LM7\AppData\Local\Temp\arduino_cache_399328 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Program Files\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'arduino_due_x_dbg' from platform in folder: C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11
Using core 'arduino' from platform in folder: C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11
Detecting libraries used...
"C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf  -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10802 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM  -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON '-DUSB_MANUFACTURER="Arduino LLC"' '-DUSB_PRODUCT="Arduino Due"' "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/libsam" "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/CMSIS/Include/" "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/Device/ATMEL/" "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino" "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\variants\arduino_due_x" "C:\Users\LM7\AppData\Local\Temp\arduino_build_257890\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\LM7\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf  -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10802 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM  -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON '-DUSB_MANUFACTURER="Arduino LLC"' '-DUSB_PRODUCT="Arduino Due"' "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/libsam" "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/CMSIS/Include/" "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/Device/ATMEL/" "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino" "-IC:\Users\LM7\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\variants\arduino_due_x" "C:\Users\LM7\AppData\Local\Temp\arduino_build_257890\sketch\Blink.ino.cpp" -o "C:\Users\LM7\AppData\Local\Temp\arduino_build_257890\preproc\ctags_target_for_gcc_minus_e.cpp"
exit status 1
Really verbose.
I guess it's saying the file C:\Users\LM7\AppData\Local\Temp\arduino_build_257890\sketch\Blink.ino.cpp doesn't exist? Do you see that file on your system? Note that the Arduino IDE deletes that folder when you exit and the build folder has a different name each time so you would need to check what the new name is if you've exited since that output.
Yes, I can see the Blink.ino.cpp file.
After studying the long error message, I found that it seems to say that 4.8.3-2014q1/bin/arm-none-eabi-g++ is missing. But arm-none-eabi-g++.exe is there, I checked.
Should I delete the whole C:\Users\LM7\AppData\Local\Arduino15 folder? And perhaps install the Ide once again.
It works now. I deleted the Arduino15 folder and restarted the machine.
Thank you all for helping
