Topic: Arduino M0 - Loads sketch but won't run, serial port disconnects. (Read 477 times) previous topic - next topic
winchymatt
I've juts got a new Arduino M0, I have my sketch compiled and it seems to load, however that's as far as  I get. It seems that the serial port keeps dissapearing.
When I press the reset button, the LED flashes fast, and the serial port appears "COMXX (ardiono M0)"
However, after 10 seconds the led stops flashing, fades out and the COM port dissapears!
So, although I can program the sketch within this time, I can't seem to get it to run.. and the port keeps dissapearing!?
Any help appreciated.
ballscrewbob
There is a lot of helpful hints and tips in the MKR1000 and MKR Zero section that may be of use to you.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
winchymatt
Sorted this thanks. I was reading horror stories of the M0 / Zero not working in .cc only in .org etc so thought it was a bigger issue, however, turned out to be a bad sketch, tired the blink sketch, that worked, then found an issue in a library of my own sketch. sorted.
