Topic: I once used Arduino Uno as a HID, and I can't turn it back to normal Arduino. (Read 1 time) previous topic - next topic
pineappleman
I once turned my Arduino into a USB device(HID?) to use Arduino Uno as a keyboard.
http://blog.naver.com/msyang59/220064215723
I followed the instructions on the page above(The contents on the page are written in Korean since I am Korean...). I installed dfu-programmer software and uploaded the keyboard firmware on Atmega16U2.
And now I want to turn it back to normal. The page above says I should just erase the dfu-programmer software from the folder where it is. But since I am not using the computer which I used to upload the software and keyboard firmware, I can't erase the software properly.
I think now I erased the keyboard firmware and dfu-programmer software from the device manager. But now, I think the computer doesn't recognize Arduino. I reinstalled the IDE and Arduino driver, but I can't find anything different in the device manager.
What should I do?
pert
I don't have experience with doing this but you should be able to find the original firmware that was on the ATmega16U2 in the Arduino IDE installation folder at hardware/arduino/avr/firmwares/atmegaxxu2. Once you flash the ATmega16U2 with that firmware it should start working again as usual.
pineappleman
Um... How can I flash ATmega16U2 with the firmware? I am not familiar with these kind of things... can you tell me how should I flash it?
pert
Probably the same way you uploaded the keyboard firmware, just with the filename found at the folder I posted above, I believe the correct file is  Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex
pineappleman
Um... the thing is, that I can't use the computer I used to upload the keyboard firmware currently, so I can't find the proper folder path.
Should I re-upload the dfu-programmer software and then erase it?
pert
You don't upload the dfu-programmer software. You use the dfu-programmer software to upload the firmware file to the ATmega16U2.
  • Download the dfu-programmer software from http://dfu-programmer.sourceforge.net/
  • Install dfu-programmer software following the instructions in the link you posted.
  • Follow the instructions at the "Revert USB Firmware" (USB 펌웨어 되돌리기) section of the link you posted. You may need to adjust the path to the file Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex because that command assumes your Arduino IDE is installed at C:\arduino-1.0.5-r2\ and also newer IDE versions have a slightly different folder structure (avr folder)/
pineappleman
