Topic: relay JD-VCC connection (Read 13141 times) previous topic - next topic
FranticKid
Pic of relay module is attached below, it has only one GND
As i want to use a separate power supply of 5V,  i connected separate supply's +Ve terminal to JD-Vcc  and -Ve terminal to  "GND-IN1-IN2-IN3-IN4-Vcc"'s   GND of relay module.... and connected Arduino's 5V to "GND-IN1-IN2-IN3-IN4-Vcc"'s Vcc...  does this connection make the relay optically isolated?????
larryd
#1
Apr 13, 2017, 05:52 am Last Edit: Apr 13, 2017, 05:55 am by LarryD
Would be similar to this four relay board.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
756E6C
#2
Apr 13, 2017, 06:04 am Last Edit: Apr 13, 2017, 07:27 am by 756E6C
Try this, 5V of course: graphic by @dlloyd.
FranticKid
756E6C bro,
the module i'm using doesnt have 2 GNDs... only 1 GND... only 2 pin header (JD-Vcc, Vcc)..
larryd
#4
Apr 13, 2017, 06:13 am Last Edit: Apr 13, 2017, 06:14 am by LarryD
From dlloyd
No technical PMs.
FranticKid
LarryD
so u r telling me everything's ok with my connection???
FranticKid
larryd
If you are wired as in post 4, you have opto isolation.
No technical PMs.
terryking228
#8
Apr 13, 2017, 04:57 pm Last Edit: Apr 13, 2017, 04:58 pm by terryking228
Larry's right: Post 4 in the right way. NO connection to Arduino GND..
Some more information about all this HERE
The circuit and the isolation barrier look like this:
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Wawa
@terryking228
I think that diagram should be modified to make things clear.
The two VCCs (opto and jumper) need to be connected, since they are on the board.
Then the isolation barrier needs to be re-drawn throught the jumper.
Leo..
terryking228
@Wawa, Good Idea! How is this??
Wawa
