Topic: Best programming language for beginners? (Read 9354 times) previous topic - next topic
GoForSmoke
#30
Apr 18, 2017, 08:34 am Last Edit: Apr 18, 2017, 08:48 am by GoForSmoke
x=3.14159
print x
3.14159
i%=x
print i%
3
Sometimes it's just about playing with the blocks directly, getting to know the shapes.
Structure? There are concepts that don't even need code to demonstrate directly, instantly.
We do get people on the forum who are semi-clueless mimes when it comes to variables despite writing scores of lines of well it runs code. That's just success waiting for help to happen, right? It it wasn't waiting, it would have happened.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
GoForSmoke
Pascal was indeed designed as a teaching language.   But that was back in the mid-1970s, and it's been a bit neglected since the 1980s.  To be useful, it needs "extensions" beyond the basic language, which are somewhat poorly standardized.   I became disenchanted with Pascal when I realized how much it cheats - the language has features and syntax that a user can't duplicate (at least, not without more 'extensions.')  And the extent to which it seemed to deliberately limit itself to be ONLY a "teaching language" (not that that lasted.   For a long time, a lot of the Apple system and application software was written in a Pascal-like language.)
I still have my 1985 Byte issue where Niklaus Wirth wrote that to get a program right you write it twice and throw the first one away. Then he wrote that Pascal is that first one, Modula is the one to keep. And who am I to argue? I've helped fix Pascal homework because logic is logic but I swear that language is more anal-retentive than COBOL. I never tried the next step into that.
Robin2
Sheesh - I was getting all psyched up for your Modula introduction  :)
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
westfw
Quote
I dunno.  Can you actually do loops and stuff "interactively"?  Certainly not in some of the microcontroller BASICs.
BASIC was my first language, and I've even written BASIC for work (a long time ago) (ok: BASIC and x86 machine language!)   I don't remember ever doing much with "interactive mode" (debugging perhaps?) - maybe the interpreters I used didn't have that feature?  In any case, that's just a glorified calculator - part of programming is planning the whole thing ahead...
(I had to look at i%=x for quite a while before stopped thinking "modulus?  BASIC doesn't do THAT!"  :-) )
(Hopefully you don't have to do  LET x=3.14159 )
(Heh.  LISP and FORTH have fine interactive interpreters as well, but I'm not going to recommend them either.  Python does pretty well as an interactive interpreter:
>>> x=3.14159
>>> print x
3.14159
>>> i = int(x)
>>> print i
3
for i in [x/6, x/4, x/3, x/2, x]:
...   print sin(i)
0.499999616987
0.707106312094
0.866024961519
0.999999999999
2.65358979335e-06
Robin2
You can do the same sort of thing with Ruby and many of the introductions to both languages use the interactive interpreter. However I have never been able to see the point of it myself.
If I want to do calculations I have a calculator.
If I want to write a program then I want to save it in a file so I can use it over and over - or amend it if I've got it wrong.
...R
msssltd
#35
Apr 19, 2017, 12:57 am Last Edit: Apr 19, 2017, 12:58 am by MattS-UK
I studied Latin in school. It's great, Today I can speak it with absolutely no one.
Apples and oranges.  The first commercially useful program I wrote was in BASIC and VB is probably the language I have made most money from.  I did some assembler and C/C++.  Then I had to do a couple of projects in Delphi and it brought clarity, to what I had been hacking away at for years.  Type, scope and OOP particularly, made so much more sense.  When I went back to C++ it was so much easier to write clear, bug free code, first time around.  When I switch to another language or dialect, the important lessons are carried from Pascal and just have to learn some new keyword and fit within the syntax of the constructs provided.
Quote from: Robin2
Tosh!
Sounds like the 1950s classroom where Python belongs.  Where kids were punished for writing with their left hand, just because.  Indentation has no computational value.  It should not cause a compiler to choke.  Indentation is for humans and should remain in the human domain.  If it is that important, have the editor impose it automatically.  While you are still trying to learn what a variable is, worrying about whitespace is a distraction nobody needs.  Clearly this is a personal opinion ;)
jremington
#36
Apr 19, 2017, 04:47 am Last Edit: Apr 19, 2017, 04:52 am by jremington
Quote
Once you learn how to use BASIC you'll never use it again.
Nonsense!!!
I have a Toshiba T1200 laptop with an LCD screen from about 1988 that runs QBASIC in DOS 3.3.
I still use it to collect data for my weather station.  A 720K floppy disk holds months of data, and the laptop runs for hours on 6xAA batteries if the power goes out!
Also keeps a nice plot of the last ~20 hours of average wind speed and gusts on the screen.
For the BASIC aficionados among you, here is the wind gauge code:
Code: [Select]
REM read wind gauge and store statistics on disk.
REM circular buffer push and pull
DECLARE SUB gbuf (array!(), v!, nsp%, nsmax%)
DECLARE SUB pbuf (array!(), v!, ns%, nsp%, nsmax%)
REM plot wind speed data in box 1-600 on x, 0-99 on y, lower screen
DIM t0(600), t1(600)
DEFINT I-N
DEFSNG K
nsec = 300 'sample save interval in seconds
SCREEN 2 '640x200
' VIEW defines graphics viewport in absolute screen coords, subsequent
' pixel coords are relative to view window
' VIEW SCREEN  (ditto) but subsequent pixel coords are absolute
' Order of coordinate pairs is immaterial!
VIEW (21, 98)-(620, 198), , 1: REM view won't frame extreme edges
WINDOW (1, 0)-(600, 99): REM logical coords 1-600 on x, 0-99 on y
CLS
OPEN "com1:4800,n,8,1,cs0,ds0,cd0" FOR INPUT AS #1
LOCATE 1, 1: PRINT "Starting wind monitor at: "; DATE$; " "; TIME$
LOCATE 2, 1
INPUT "Output file name: ", n$
OPEN n$ FOR OUTPUT AS #2
PRINT #2, DATE$; " "; TIME$; " sample:"; nsec
r% = 0
REM number of points in graph, buffer pointers
n0m = 300: n0 = 0: n0p = 1
n1m = 300: n1 = 0: n1p = 1
REM get version #
'ON ERROR GOTO handler
LINE INPUT #1, a$
LOCATE 3, 1: PRINT "Version and time: "; a$
LOCATE 4, 1: PRINT "Hit Esc to exit..."
nsamp = 0: wmaxt0 = 0: avgt0 = 0: vart0 = 0
ON TIMER(nsec) GOSUB 5000
TIMER ON
10 LINE INPUT #1, a$: LOCATE 9, 33: PRINT a$; "     "
nc = INSTR(a$, ","): a$ = MID$(a$, nc + 1)
15      temp0 = VAL(a$) / 22.6
nc = INSTR(a$, ",")
20      temp1 = VAL(MID$(a$, nc + 1)) / 22.6: REM max reported by sensor
IF (wmaxt0 < temp1) THEN wmaxt0 = temp1
avgt0 = avgt0 + temp0
vart0 = vart0 + temp0 * temp0
nsamp = nsamp + 1
LOCATE 11, 26
PRINT USING "& Avg: ### Max: ### mph"; LEFT$(TIME$, 5); temp0; temp1;
IF INKEY$ <> CHR$(27) THEN GOTO 10
REM escape key hit, all done
GOSUB 5000
CLOSE #2
STOP
5000 r% = r% + 1: REM write record: average, max and s.d. this interval
avgt0 = avgt0 / nsamp
vart0 = vart0 / nsamp - avgt0 * avgt0
vart0 = SQR(ABS(vart0))
PRINT #2, USING "###.#,###.#,###.#"; avgt0; wmaxt0; vart0
CALL pbuf(t0(), avgt0, n0, n0p, n0m)
CALL pbuf(t1(), wmaxt0, n1, n1p, n1m)
nsamp = 0: avgt0 = 0: wmaxt0 = 0: vart0 = 0
REM plot data
CLS 1
' dotted gridlines
FOR i = 1 TO 600 STEP 4
PSET (i, 30): LOCATE 21, 4: PRINT "10";
PSET (i, 60): LOCATE 17, 4: PRINT "20";
PSET (i, 90): LOCATE 13, 4: PRINT "30";
NEXT i
' pull out most recent temp0 and max measurements
nsp = n0p
FOR i = n0 TO 1 STEP -1
CALL gbuf(t0(), v, nsp, n0m)
v = 3 * v: i2 = 2 * i
PSET (i2, v): PSET (i2, v + 1): PSET (i2, v - 1): PSET (i2 + 1, v): PSET (i2 - 1, v)
NEXT i
RETURN
handler:
LOCATE 3, 30
PRINT "error "; ERR; " at line "; ERL; TIME$; " "; DATE$;
LOCATE 4, 30
PRINT a$
RESUME NEXT
DEFINT K
DEFINT I-N
REM NO check for buffer underflow
v = array(nsp)
nsp = nsp - 1
IF nsp < 1 THEN nsp = nsmax
END SUB
DEFINT I-N
REM returns ns%, number of values pushed
array(nsp) = v
nsp = nsp + 1: ns = ns + 1
IF nsp > nsmax THEN nsp = 1
IF ns > nsmax THEN ns = nsmax
END SUB
Robin2
That may be true of the visual part of it. But I can't see any technical difference between starting a block of code with a TAB character or starting it with a '{' character. And it saves me having to type the closing '}' And as a side effect it makes the code easy to read
Get over it  :)
...R
westfw
Quote
have the editor impose [indentation] automatically.
And of course, Python editors DO that.
I was a little surprised at how little the "whitespace issue" bothered me when using python.  I mean, it's only INDENTATION that matters; other whitespace is still malleable.
(Hmm.  Look at it this way: it's not the first time when a "recommended practice" has become a "required behavior of the language."  The other main one I can think of is pre-declaring your variables (C, Pascal, PL/1...) (something that Python got rid of...))
GoForSmoke
#39
Apr 19, 2017, 10:36 am Last Edit: Apr 19, 2017, 10:52 am by GoForSmoke
>>> x=3.14159
>>> print x
3.14159
>>> i = int(x)
>>> print i
3
...   print sin(i)
0.499999616987
0.707106312094
0.866024961519
0.999999999999
2.65358979335e-06
My first Basic let me use bits in integer vars. I consider learning bits early to be important foundation knowledge.
Is Python deficient in that department?
I think the real beauty of Basic for Beginners is that they can get utterly sick of it before too long and move on to better. If you start on a hilltop that's going to be harder to do.
msssltd
#40
Apr 19, 2017, 12:40 pm Last Edit: Apr 19, 2017, 12:45 pm by MattS-UK Reason: multi quote
Was that some sort of pun. ;)
I can see '{' and '}' characters but I can't see a TAB character, or any other white space or control characters.
Quote
Get over it  :)
I am over it, but from a beginners perspective, I think it is better to be encouraged to consider the purpose of adding white space to increase human readability, than be taught to slavishly please a compiler.
I bet you just loved learning tables by rote too :D
Quote
Pre-declaring variables in Pascal, teaches you how a procedure, function or unit is arranged in memory.  It makes it very easy to see where and why variables fall out of scope.  Similarly Pascal type declarations, which can seem unwieldy but you soon get your head around type equivalency.
Not that type and scope are important computing concepts in any way :D
Robin2
Yeah. A nice sense of achievement :)
...R
TomGeorge
First computer language was psuedo-code to introduce HPBasic. (Secondary School)
The only computer you needed was your brain, the input device, eyes and blackboard , output device hardcopy pen and paper, RAM another piece of paper.
Even learnt flowcharting.
HPBasic was on cards you used a HB pencil to cross out squares to optically encode the card.
Turn around time three days, one day on the bus to the computer, one day for program run (if it did), one  day of bus to bring it back.
So mistakes wasted very valuable programming time at school.
By the way does anybody remember what   1H1 in a fortran print format statement did, especially if it was trapped in a loop?
Apart from raising the blood pressure of the Computer Centre Manager.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
GoForSmoke
Is that the Halt Catch Fire command?
TomGeorge
Just about.
It tells the lineprinter to go to the top of the next page.
If its trapped in a loop, you have fanfold paper cascading, in a magnificent arc, out the top of the lineprinter.
:o :o :o :o :o
