Topic: Neopixel and SD card (Read 8075 times) previous topic - next topic
Grumpy_Mike
Is that the issue you think?
Well it is worth a shot. Does it happen with overall low light levels or does it just happen when things are bright?
This points to a poorly regulated supply or a power distribution problem. Capacitors can help with the power distribution.
Yes they are in the right place.
Is their any pattern to the misbehaving pixels? Like are they on the edge or middle of the display?
mooop
It does seem to only happen with bright colors indeed.
I don't believe so. It's pretty random, in the center as well.
Grumpy_Mike
#62
May 22, 2017, 06:09 pm Last Edit: May 22, 2017, 06:09 pm by Grumpy_Mike
That seems to suggest a power supply problem.
In might be thermal, does this happen when you first switch on or is it only after they have been running for some time?
Sorry I can't be more definitive.
