Topic: how to add New Boards to arduino 1.8.2  (Read 8831 times) previous topic - next topic
bandmwhitt2013
Hello Im trying to add new boards to arduino from github i added the URLs and put a copy of the files
in the hardware folder ....and still nothing ....I have several controllers that arduino does not provide
like atmega16& 32 Im trying to add those I really am trying to avoid messing with the boards.txt file
does anyone know what Im not doing or what I am doing wrong ?
DrAzzy
#1
Apr 28, 2017, 09:22 pm Last Edit: Apr 28, 2017, 09:23 pm by DrAzzy
EITHER (not both!!!!)
Use board manager. Add the URLs to the board manager URLs in the settings. Then open board manager with tools -> board manager, select the desired board package (you want the one from MCUdude)
OR
Install manually - extract into a folder in the hardware folder in your sketchbook folder (document folder\Arduino - you may need to create the hardware folder there. With some cores, you can sync their github repo into the hardware folder.
See the installation section of MCUDude's MightyCore for more info:
https://github.com/MCUdude/MightyCore
Never modify the files in the directory you installed Arduino to. It's not expecting that anymore, and windows will play games if you try to modify files there due to User Account Control File and Registry Virtualization if you're on Windows Vista or later too.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
bandmwhitt2013
OK.... I added the URLs and deleted the extra folders ..went to boards manager and they do not show up ?
at all I looked in contributed and then in all boards and i do not see anything new I made sure i put the
URL in correctly so Im stumped once again ?
bandmwhitt2013
OK i went with option 2 ...Worked :D Thanks DrAzzy ...
