Topic: Will this dc power supply work with arduino? (Read 493 times) previous topic - next topic
KarolHo
just like in the title, will this power adapter work with arduino? link
(The EU 3A variant)
ballscrewbob
#1
Apr 30, 2017, 02:17 pm Last Edit: Apr 30, 2017, 02:19 pm by Ballscrewbob
it will work BUT when powering Arduinos you are better with a slightly lower voltage 7.5 to 10 Volts.
There seemed to be a period where 12 volts was causing some issues with components on the real Arduinos.
Clones seemed unaffected.
The higher the voltage the more work the regulator has to do to reduce the voltage to around 5 volts.
The reduction in voltage just generates heat in the components.
Also you dont need any more than 1 Amp.
If you are running other items such as motors etc they should have thier OWN power supply with just a shared common ground.
If that is the case then order another PSU. AT that price it is a bargain...
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
