Topic: 這bug好難處理 (Read 3292 times) previous topic - next topic
xznm0216
目前有點小問題,目的是要讓超音波感測到障礙物時會馬達會停止,沒有障礙物時馬達會動作,但現在因為有加進PWM去控制速度,但是這LOOP裡的速度會影響到SWITCH的速度,比方說當啟動FORWARD時速度是127但維持時間只維持很短,delay完就回到LOOP的速度191去,但拿掉那段後,速度維持的時間是持續的,但有點缺陷是感測到障礙物時停止,但當障礙物移走後就不會自行啟動了,請問要如何修正?
#include <SoftwareSerial.h>
#include <Wire.h>
#include <stdio.h>
int enablePin = 6;
int motorPin1 = 3;
int motorPin2 = 5;
int trig = 9 , echo = 8 ;
int beep = 12;
char x;
byte dis[6];  //distance package
SoftwareSerial BT(10, 11); // RX, TX
float distance = 0;
char dischar[4];
int i=0;
float Length()
  float duration, distancetmp;
  digitalWrite(trig, HIGH);
  delayMicroseconds(1000);
  digitalWrite(trig, LOW);
  duration = pulseIn (echo, HIGH);
  distancetmp = (duration / 2) / 29;
  return distancetmp;
  BT.begin(9600);
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(enablePin, OUTPUT);
  pinMode(trig, OUTPUT);
  pinMode(echo, INPUT);
  pinMode(beep, OUTPUT);
  digitalWrite(motorPin1, LOW);
  digitalWrite(motorPin2, LOW);
  digitalWrite(enablePin, LOW);
  distance = Length();
  if (distance < 20)
    Serial.print("WARNING!");
    Serial.print("Obstacle!!");
    digitalWrite(beep,HIGH);
    digitalWrite(beep,LOW);
    analogWrite(enablePin, 0);
    Serial.print("OK!");
    analogWrite(enablePin, 191);
  Serial.print("distance = ");
  Serial.print(distance);
  Serial.println("cm");
  int sendData = (int) (distance * 100); //times 100 and convert disance to integer
  byte packet[3];
  packet[0] = 97;
  packet[1] = sendData / 256; //divides sendData to two 1 byte packets
  packet[2] = sendData % 256;
  if ( BT.available()>0)
    if (BT.read() == 97)
    for(int i = 0; i < 3; i++)
    BT.write(packet);
    val = BT.read();
  switch(x)
      case 'F':   // car forward
                forward();
      case 'B':   // car back
                back();
      case 'S':   // car stop
                motorstop();
      case 'H':   // speed high
                motorhigh();
      case 'M':   // speed mid
                motormedian();
      case 'L':   // speed low
                motorlow();
void motorstop()
  Serial.println("Stop!");
void forward()
  Serial.println("Forward!");
  digitalWrite(motorPin1, HIGH);
  analogWrite(enablePin, 127);
void back()
  Serial.println("Back!");
  digitalWrite(motorPin2, HIGH);
void motorhigh()
  Serial.println("High!");
  analogWrite(enablePin, 255);
void motormedian()
  Serial.println("Median!");
  analogWrite(enablePin, 150);
void motorlow()
  Serial.println("Low!");
  analogWrite(enablePin, 64);
