Topic: MKRFox lowpower.sleep not working (Read 3779 times) previous topic - next topic
hieronymousch
I can't get the lowpower to work... The board goes to sleep indefinitely. Replacing sleep with delay works fine.
Anybody an idea what can cause this? Simple setup with a onewire temperature sensor.
Here's the code. I'm new at this so probably some stupid mistake. Any help is appreciated.
#include <SigFox.h>
#include <ArduinoLowPower.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define UINT16_t_MAX  65536
#define INT16_t_MAX   UINT16_t_MAX/2
// Set debug to false to enable continuous mode
// and disable serial prints
int debug = false;
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
typedef struct __attribute__ ((packed)) sigfox_message {
  uint8_t status;
  int16_t moduleTemperature;
  int16_t ExtTemperature1;
  int16_t ExtTemperature2;
  uint8_t lastMessageStatus;
} SigfoxMessage;
int16_t convertoFloatToInt16(float value, long max, long min) {
  float conversionFactor = (float) (INT16_t_MAX) / (float)(max - min);
  return (int16_t)(value * conversionFactor);
// stub for message which will be sent
SigfoxMessage msg;
  if (debug == true) {
    while (!Serial) {}
  if (!SigFox.begin()) {
    //something is really wrong, try rebooting
    reboot();
  //Send module to standby until we need to send a message
  SigFox.end();
  //if (debug == true) {
    // Enable debug prints and LED indication if we are testing
    SigFox.debug();
  // start sensors
  sensors.begin();
 msg.status = 1;
  // if we get here it means that an event was received
  // lees temperaturen uit
  sensors.requestTemperatures(); // Send the command to get temperature readings
  float temperature1 = sensors.getTempCByIndex(0);
  float temperature2 = sensors.getTempCByIndex(1);
  msg.ExtTemperature1 = convertoFloatToInt16(temperature1, 60, -60);
  msg.ExtTemperature2 = convertoFloatToInt16(temperature2, 60, -60);
  SigFox.begin();
  delay(100);
  // interne temperatuur bordje
  float temperature = SigFox.internalTemperature();
  msg.moduleTemperature = convertoFloatToInt16(temperature, 60, -60);
    Serial.println("temp1: " + String(temperature1));
    Serial.println("temp2: " + String(temperature2));
   Serial.println("Internal temp: " + String(temperature));
   Serial.println(String(msg.moduleTemperature));
  // Clears all pending interrupts
  SigFox.status();
  delay(1);
  SigFox.beginPacket();
  SigFox.write((uint8_t*)&msg, 12);
  msg.lastMessageStatus = SigFox.endPacket();
    Serial.println("Status: " + String(msg.lastMessageStatus));
  SigFox.end();
    // spin forever, so we can test that the backend is behaving correctly
    while (1) {}
  //Sleep for 15 minutes
  LowPower.sleep(15 * 60 * 1000);
void reboot() {
  NVIC_SystemReset();
  while (1);
astroman35
Try to add this line to your setup function :
LowPower.attachInterruptWakeup(RTC_ALARM_WAKEUP, dummy, CHANGE);
hieronymousch
Sorry for replying so late but this won't compile
exit status 1
'dummy' was not declared in this scope
Thanks for the tip, I keep on looking
hieronymousch
OK... noob error
You have to add the dummy function in your sketch
void dummy() {
  // This function will be called once on device wakeup
  // You can do some little operations here (like changing variables which will be used in the loop)
  // Remember to avoid calling delay() and long running functions since this functions executes in interrupt context
ghurbain
what do you have to put in the dummy function ? a reboot / reset operation ? or keep empty like this and it'll start auto the loop void ?
nimasa
it could be any simple thing. Just declare a variable there. Something like:
void dummy() {
  volatile int aaa=0;
valaennic
Hello,
I've had the same problem with the waking up from lowpower.sleep().
It seems that you have to use Serial1 (connected to pins 13&14, which are the TX & RX connectors) instead of the normal USB connector as the USB port may get confused during wakeup.
I just ordered this FTDI- Adapter and hope that it will allow me serial print out. Otherwise, I will just connect the mkr fox to a battery and not have ANY SERIAL connection, thus sending the data directly to SigFox.
Another thing I also read is that you may have problems with the computer recognizing the port, then you may need to install the correct driver for the FT232RL driver.
I got this information from the Author Antine de Chassey and the Video. I hope my conclusion is right and will keep you posted :)
valaennic
So I connected the FTDI - USB and installed the corresponding driver. The Port shows on Arduino 1.8.13. However, I was not able to communicate with my Arduino at all (need to verify if maybe the driver is not working correctly/ was the wrong one/ connected the pins wrong).
Consequently, I quit the serial communication and send the data directly to SigFox after the Arudino woke up from deepSleep() and made the measurements it successfully transmitted the data to SigFox. I had the code running for 24h just to verify if any hick-ups occurred.
Strangely when using the Sigfox commands the power consumption in deepSleep rose from 13uA to 60uA. Any one knows, why this might happen?
Kind regards,
