Topic: what i have been up to, thus far. (Read 48033 times) previous topic - next topic
Qdeathstar
On my pole, (i am using it has a flag pole) there are already pins that hold the sections of the telescope up. The pins only go in two ways (180 degrees from each other) The pole i linked to you is a cheap model and therefor probably only has one pin, which means it will only go together one way. On the base, you set what that way is by rotating a first leg and screwing in a set screw.
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
Qdeathstar
Qdeathstar
yeah, i was disappointed to learn that's only -40F :(
CrossRoads
Kidding, right?
The Fahrenheit and Celsius scales intersect at −40° (i.e., −40 °F = −40 °C).
Qdeathstar
yeah, i don't store that information in my head.... i know 0c freezing, 30c hot,  and 100c boiling. Other than that DONT CARE.
Qdeathstar
Maybe your next project should be a squat counter.
allanhurst
The earth rotates once in 24 hours, so you need that rev rate...   1/1440 or  about 0.000694 rpm.
Allan
Qdeathstar
I don't think a stepper would work, since it has discrete steps, you would notice the steps....
TomGeorge
Hi Travis,
For your tracker drive system , you may get some ideas from the DIY  Barndoor Trackers that track cameras.
google   barndoor tracker
Tom... :)
PS Like all of us mate we, "keep taking the tablets"   lol
Everything runs on smoke, let the smoke out, it stops running....
Qdeathstar
did they end up giving you that liscence?
