Topic: Quectel MC60 GPRS (Read 2470 times) previous topic - next topic
deep
I'm facing problem to post data to server using Quectel MC-60.
Link format to post data is:
http://xyz.in/demo/mclogger/superRentals/index.php/ard/createGpsLocationFromDevice?deviceId=95614735&key=MYKEY&ard=12.63,78.65
When I open this link using browser its working and showing success, But when i tried to post using MC60 it gives HTTP 400 - Bad Request.
Sequence of AT commands:
-> AT+CGDCONT=1,"IP","www"    (Set APN)
-> AT+CGACT=1,1                    (PDP context Active)
-> AT+CGATT=1                       (Attach GPRS)
-> AT+QIOPEN="TCP","xyz.in","80"(Start TCP Connection)
-> AT+QISEND                          (Send data through TCP)
-> http://xyz.in/demo/mclogger/superRentals/index.php          /ard/createGpsLocationFromDevice?deviceId=95614735&key=MYKEY&ard=12.63,78.65
-> CTRL+Z
Then I'm getting Error of HTTP 400 - Bad Request.
Is my Sequence of AT command is wrong?? Or Method of posting is wrong?
Thanks
junglejake
You need to ensure a response back from the Quectel, hence either do a response check or put in a delay between each request.
