Topic: GPS not getting any fix. Why? (Read 7434 times) previous topic - next topic
bestanamnetnogonsin
#15
May 22, 2017, 04:18 pm Last Edit: May 22, 2017, 04:30 pm by bestanamnetnogonsin
Quote
Are you 'printing' more characters than is in the buffer perhaps ?
In this example I do, yes. However that is intentional, as I need a "reserve" in the array because the length of the gps string is not always the same. The problem is that even If I give the buffer a starting value, say: 66 times '0' I get these corrupt characters when printing the entire buffer.
Also, that definitely is the entire message. I've tried with a 80 bit buffer too.
stowite
#16
May 22, 2017, 04:50 pm Last Edit: May 22, 2017, 04:50 pm by stowite
Seems the OP did not read my previous post. I think the message is more than the 65 characters long (the buffer size 66 -1  for the terminating zero) so is writing outside the buffer reserved for it. Any write to a variable declared following the buffer declaration could be overwriting the end of the message and so showing up as corrupt characters in the message!
-dev
Quote from: stowite
Seem the OP did not read my previous post.
Or mine.  -_-
Quote from: bestanamnetnogonsin
No, that's not the entire message, for a variety of reasons.
Why save the message if you're just printing it?  That's just an echo program:
Code: [Select]
  if (GPS.available())
    Serial.write( GPS.read() );
Really, I used to be /dev.  :(
bestanamnetnogonsin
I'm sorry if I have misunderstood something, but I have already used the function -dev- posted to print the sentence:
Code: [Select]
 I only got what I get using my other function. Therefore I assumed that this was the whole message? But maybe I am wrong?
 The reason I am saving it is because, apart from printing it, my entire program (which is more than 500 lines long, and I therefore have not posted) also saves the sentence to an SD card and transmits it via Radio. Therefore it is handy to have it saved in a buffer.
stowite
#19
May 22, 2017, 05:24 pm Last Edit: May 22, 2017, 05:26 pm by stowite
One last try ! IF THE MESSAGE IS LONGER THAN THE 65 CHARACTER BUFFER ALLOCATED TO HOLD IT THEN YOU MAY BE WRITING BEYOND THE END OF THE BUFFER!
bestanamnetnogonsin
Look, maybe I'm missing something here, but if I do not use the buffer at all, and instead only print the sentence with this function:
Code: [Select]
Then I only get a message of the same length as I posted. How can the message possibly be any longer than 65 chars?
stowite
Code: [Select]
A quick count of the characters in the message you posted earlier indicated more than 65 characters. Have you printed out the length? If not then do so before doing anything else! If I am right then you have solved one of your problems. If I am wrong then you will have one less thing to eliminate.
Have you made sure the terminating NULL char is appended to the message?
When I write a sequence of characters to a character buffer I check that there is room before writing to it. I also add the terminating zero after each character is written; OK that may be overkill but it works.
-dev
if I do not use the buffer at all, and instead only print the sentence with this function... Then I only get a message of the same length as I posted. How can the message possibly be any longer than 65 chars?
Because you must have other things in loop.  That's not a function I provided, that's the only thing loop should do.  That simple echo sketch will absolutely print the complete message.
I don't know why you think this is a complete message:
  $PUBX,00,154106.00,4732.65609,N,00733.55878,E,364.181,G3,12,19,���,
Here's an example from the ublox NEO-6 spec, section 21.2:
  $PUBX,00,081350.00,4717.113210,N,00833.915187,E,546.589,G3,2.1,2.0,0.007,77.52,0.007,,0.92,1.19,0.77,9,0,0*5F
Obviously, you are not saving the the whole sentence in your buffer.  You are missing almost half of the data.  Your program prints only what it was able to save.  If you really want to "save the sentence to an SD card", just do this:
Code: [Select]
    sdFile.write( GPS.read() );
You finally tell us that your sketch "transmits it via Radio. Therefore it is handy to have it saved in a buffer."  Now we know a little more about what you're trying to do.
There are many ways to send GPS information over the radio.  Raw NMEA data is the worst.  The 111-byte PUBX sentence is 10x bigger than a binary radio message.  Let's say you are sending lat, lon and altitude.  Here is a simple text representation of those 3 numbers:
    48.11730,11.51667,545.5
That's 24 bytes, and the receiver has to parse the fields into numbers for calculations.  Here is a binary representation of those 3 numbers:
    1CAE1E086DD4DCBD516
That's only 10 bytes (displayed with 20 hex characters).  It could be sent with one transmission:
    radioSend( (uint8_t *) &gpsDataStruc, sizeof(gpsDataStrcut) );
... and the receiver would not have to parse anything.  The received bytes can be copied directly onto a matching structure.  If your radio (which radio?) can only send 32-byte packets, it would take 4 packets to send the raw data.  If your radio takes longer than 250ms to send a packet, it can't keep up with the raw NMEA data stream.
The other problem in your sketch is that it uses delay.  A contributing factor is that it uses SoftwareSerial.
FWIW, you can expect testy responses when you don't recognize contributors for offering suggestions.  We all want to help -- the least you can do is acknowledge the transmission.
And the more information you tell us, the better the answers will be.  If your code is too big to embed in a post, just attach it as a file with the Attachments and other options in the lower right-hand corner of the post editor.
bestanamnetnogonsin
Thank you for all of your answers. But what I have been trying too say is this: When I test the GPS with this sketch (nothing else):
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial GPS(3, 5);
byte gps_set_sucess = 0 ;
  GPS.begin(9600);
  // START OUR SERIAL DEBUG PORT
  Serial.println("GPS Level Convertor Board Test Script");
  Serial.println("03/06/2012 2E0UPU");
  Serial.println("Initialising....");
  // THE FOLLOWING COMMAND SWITCHES MODULE TO 4800 BAUD
  // THEN SWITCHES THE SOFTWARE SERIAL TO 4,800 BAUD
  GPS.print("$PUBX,41,1,0007,0003,4800,0*13\r\n");
  GPS.begin(4800);
  GPS.flush();
  //  THIS COMMAND SETS FLIGHT MODE AND CONFIRMS IT
  Serial.println("Setting uBlox nav mode: ");
  uint8_t setNav[] = {
    0xB5, 0x62, 0x06, 0x24, 0x24, 0x00, 0xFF, 0xFF, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x10, 0x27, 0x00, 0x00,
    0x05, 0x00, 0xFA, 0x00, 0xFA, 0x00, 0x64, 0x00, 0x2C, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x16, 0xDC };
  while(!gps_set_sucess)
    sendUBX(setNav, sizeof(setNav)/sizeof(uint8_t));
    gps_set_sucess=getUBX_ACK(setNav);
  gps_set_sucess=0;
//ADDED THIS//////////////////////////////////////////////////////////////////////////////////////
GPS.println("$PUBX,40,GLL,0,0,0,0*5C");
GPS.println("$PUBX,40,GGA,0,0,0,0*5A");
GPS.println("$PUBX,40,GSA,0,0,0,0*4E");
GPS.println("$PUBX,40,RMC,0,0,0,0*47");
GPS.println("$PUBX,40,GSV,0,0,0,0*59");
GPS.println("$PUBX,40,VTG,0,0,0,0*5E");
  GPS.println("$PUBX,00*33");
  delay(2000);
  while(GPS.available()){
    Serial.write(GPS.read());
// Send a byte array of UBX protocol to the GPS
void sendUBX(uint8_t *MSG, uint8_t len) {
  for(int i=0; i<len; i++) {
    GPS.write(MSG[i]);
    Serial.print(MSG[i], HEX);
  GPS.println();
// Calculate expected UBX ACK packet and parse UBX response from GPS
boolean getUBX_ACK(uint8_t *MSG) {
  uint8_t b;
  uint8_t ackByteID = 0;
  uint8_t ackPacket[10];
  unsigned long startTime = millis();
  Serial.print(" * Reading ACK response: ");
  // Construct the expected ACK packet
  ackPacket[0] = 0xB5;  // header
  ackPacket[1] = 0x62;  // header
  ackPacket[2] = 0x05;  // class
  ackPacket[3] = 0x01;  // id
  ackPacket[4] = 0x02;  // length
  ackPacket[5] = 0x00;
  ackPacket[6] = MSG[2];  // ACK class
  ackPacket[7] = MSG[3];  // ACK id
  ackPacket[8] = 0;   // CK_A
  ackPacket[9] = 0;   // CK_B
  // Calculate the checksums
  for (uint8_t i=2; i<8; i++) {
    ackPacket[8] = ackPacket[8] + ackPacket[i];
    ackPacket[9] = ackPacket[9] + ackPacket[8];
  while (1) {
    // Test for success
    if (ackByteID > 9) {
      // All packets in order!
      Serial.println(" (SUCCESS!)");
      return true;
    // Timeout if no valid response in 3 seconds
    if (millis() - startTime > 3000) {
      Serial.println(" (FAILED!)");
      return false;
    // Make sure data is available to read
    if (GPS.available()) {
      b = GPS.read();
      // Check that bytes arrive in sequence as per expected ACK packet
      if (b == ackPacket[ackByteID]) {
        ackByteID++;
        Serial.print(b, HEX);
      else {
        ackByteID = 0;  // Reset and look again, invalid order
Then the only thing I get is something looking like this:
Code: [Select]
And nothing else.
srnet
Well this new sketch is quite different to the first one you said you were using in post #11 ("Here's the code I use:").
So now, with this new code, you request the sentence from the GPS with;
Wait two seconds, by which time the entire sentence has had plenty of time to arrive, and try to read it from the buffer.
What value did you set for the softserial buffer size, you did not say ?
No PMs please, they dont get answered.
-dev
Quote
So, you didn't try the echo program?  Why not?
Quote
Then the only thing I get is something looking like this... And nothing else.
Are you asking "Why?"
It uses delay, the surest way to break a GPS program.  Read the first paragraph here and here.
It uses SoftwareSerial, the surest way to break other parts of your program, or lose data from other devices.  Read this.
If you insist on saving the raw NMEA data, you should go back to "Serial Input Basics" in the Useful Links page.
I see you are using a LoRa radio, so you better check the data rates and packet sizes.  Sending fewer bytes might become more interesting.
Instead of sending a poll for the PUBX,00 sentence, just configure the NEO-6M to send it once per interval, during setup, by using the CFG_MSG command.  See section 31.9.2, and use the table in section 19.
Boardburner2
Ok good news. Seems the inside testing was the problem. I have finally got a fix.  I didn't realize that the antenna is so weak.
Were you expecting it to work through a window ?
Many modern windows have dielectric coatings, as do Renault vans if you want to use a tom tom.
srnet
Although the Ubloxes are capabale of putting out their custom sentences, I dont really understand why people try to use it in tracker applications.
I have seen it said that it allows you to request the GPS to send a (custom) location sentence when you want it. It seems you then have to write your own custom routines to parse the Ublox data into real GPS co-ordinates.
There are excellent GPS libraries that do all the sentence parsing for you, and if you use them your application is not locked into the requirements of a specific GPS. Its also trivial to request a fix when you want it.
So can the OP provide any illumination, what is the benefit of using the Ublox specific sentences ?
