Topic: Writing password to flash memory on Due (Read 479 times) previous topic - next topic
Benoson
Code: [Select]
Karma: 4  [add]
5.102.207.87
DueFlashStorage help with code
Today at 07:50 am
Hello, i am using the DueFlashStorage library and my purpose is to change an array of 4 chars (trough keypad) and to write that to the flash memory.
Here is my code:
Code: [Select]
#include <DueFlashStorage.h>
DueFlashStorage dueFlashStorage;
#include <Keypad.h>
const byte numRows = 4;
const byte numCols = 4;
char keymap [numRows][numCols] =
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins [numRows] = {6, 7, 8, 9};
byte colPins [numCols] = {2, 3, 4, 5};
Keypad myKeypad = Keypad (makeKeymap (keymap), rowPins, colPins, numRows, numCols);
char pass[4];
int counter =0;
  dueFlashStorage.write(0,pass[0]);
  dueFlashStorage.write(1,pass[1]);
  dueFlashStorage.write(2,pass[2]);
  dueFlashStorage.write(3,pass[3]);
  char keypressed = myKeypad.getKey();
  Serial.println("Your Password Is");
  Serial.print(dueFlashStorage.read(0));
  Serial.print(dueFlashStorage.read(1));
  Serial.print(dueFlashStorage.read(2));
  Serial.print(dueFlashStorage.read(3));
  if (keypressed == 'A')
   Serial.println("");
   Serial.println("Whats the new pass?");
   while(counter < 4)
    if (keypressed)
    pass[counter] = keypressed;
    counter++;
Before i get to the  "while" it says the password is "0000".
For some reason, after the "while" (after i change the pass) it still says that the password is "0000".
Can someone help me please?
MorganS
You update the pass[] array inside the while() loop. But you never wrote it back to the flash storage. So when you read the flash storage, you get exactly what you wrote in setup().
"The problem is in the code you didn't post."
