Topic: Wire.h + Another Int Variables (Read 979 times) previous topic - next topic
dansku
http://pastebin.com/f850d698
Hi, I was playing with the RTC timer, the code was working great, then I wanted to add a temperature sensor, a code that by itself it works. Bu then when I merged the two codes, its giving a error:
Code: [Select]
In function 'void loop()':
error: expected primary-expression before '=' token
on line 127 from pastebin
does any one knows how to fix this? thanks  :)
dansku
i think its a bug/problem with the array i was using, made a different way and it worked :P
