Topic: Self-test on Simple Programming of ATmega328 using Arduino UNO Platform (Read 5415 times) previous topic - next topic
Robin2
This is the second time you have tried to hi-jack another person's Thread with your question which has absolutely ZERO to do with the Thread.
Don't do that.
Post I was referring to seem to have been removed
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
GolamMostafa
@CrossRoads
Subj : Quiz-question/Answer Review subject to mutual correction:
1. -
2. -
3. I expected:     DDRD0 = HIGH; (coneptually; it will not be compiled by IDE).
4. Why should I assume that Pin-4 is a physical pin of the MCU? How is it ambiguous? Is there any other
   possible meaning (reference) other than the metallic pin of the MCU?
5. I expected:
   byte y = 0x4F;     //(0100 1111 = p g f e d c b a = 3 =  0100 1111; 00 1111 ----> PB5 - PB0)
   PORTB = y;
   bitWrite (PORTD, 6, bitRead(y, 6));       // y = y67 y6 y5 y4 y3 y2 y1 y0
   or
   digitalWrite(6, bitRead(y, 6));
   digitalWrite(7, bitRead(y, 7));
   bitSet(0, LOW);
   bitSet(1, HIGH);
6. -
7.  (After the inclusion of the 74LS138 decoder, how many port lines are now available in the system?)
     Let us correct the Question:
     system?
have increaded in the ATmega328 system?
     I expected: 2   (we have 20 port lines in the MCU; now 74LS138 has gievn two more extra!)
8.  I expected the students to analyse every line and then come to the result; they didn't except 5.
     byte x = 0x87;                   // x = 1000 0111
     boolean n = bitRead(x, 7);   // n = 1
     bitWrite(PORTD, 7, n);        // PD7 = LH    // p (point)
     digitalWrite(1, HIGH);         // PD1 = LH   // DP2
     bitSet(PORTD, 0);              // PD2 = LH
     [first 3 lines put HIGH on pin13, so p is driven.
     PORTD bits 1,0 = 1,0 -> DP2 enabled]
     [The Proverb: British/French says:  Get the knowledge first and then analyse.
                        American says: Analyse and then find the answer.
                        American says: It will be in the market next month. Japanese says: It (the same
                            thing) is already in the market.]
  9. -
     I have a question.
     If I want to measure the internal TS's (Temperature Sensor) signal, which channel should I use
     apart from using Vref = 1.1V (INTERNAL)? Data sheet says: Ch-8. The syntax: analogRead(A8) is
     not accepted. I used analoagRead(8); the value is 60.00 deg C.  It does not
     change! I have solved the following equation based on the TS' response points: A(25 degC, 0.314V),
     B(85 degC, 0.380V).
Code: [Select]
     DECT (Decimal Temperature) = 9090909* Vdt - 2604545  (10+4 Times amplified)
     BINT (Binary temperature, 10+6 Times amplified) = 0x0EEA6D* Vht - 0x0F863864
     ( Vdt (Output DC Voltage of TS at T degC) = (Vht*1.1)/1023); Vht = ADC value at T degC.
 10. The question is to be corrected as follows:
       What output values (0 or 1) would be produced by the Question-(c) of the following
       instructions after pressing K1?
       (The students are not yet familiar with the internal structure of PORTD Latch.) I would
       accept any answer.
GolamMostafa
Quote
Don't do that.
I think that the Moderators are here to offer guide lines as they think suitable (correction, motivation, punishment, insult, threat, ..., sometimes smile!). Others might suggest Moderators to take actions; but, certainly not the reporter himself as it violates the right of defence of the to be accused!
GolamMostafa
Those including me, who are engaged in the Learning/Teaching Process of ATmega328 MCU using Arduino UNO Platform may down load the attached Experiment-2 File for practising.
Robin2
I think that the Moderators ...
The Post I was referring to seems to have been removed.
...R
GolamMostafa
Thanks and many thanks for the clarification. Let there be opportunities for us to serve ourselves and others who need a little bit help to make a move.
"We have a member in the Forum who frequently utters: The hammer sees everything as nails; but, this is practically, sometimes, false. There are 134 students in a class (nails); there is only one teacher (hammer); how does the teacher detect the 5 -- differently able?"
I have read your scholarly writing made in response to someone's thread on 'Polling opinions on learning..'  I have forgotten the location. I wish to read it again; can you please refer me to the link if you can remember?
Robin2
If that is addressed to me then I'm sorry, I can't remember. But it was probably addressed to someone else because I can't ever recall writing anything "scholarly" :)
Have you tried to see if Google can find it?
Do you know what section of the Forum it was in?
...R
AWOL
I think the usual quote is "If the only tool you have is a hammer, the tendency is to see all problems as nails".
Whatever.
If the teacher sees himself/herself as a hammer, what hope is there for any of the students?
GolamMostafa
This is the beauty of any living language, particularly, the English that it can paraphrase a given sentence (s) to bring out an impressive meaning.
