Hello all!
This is a straightforward one, at least I thought it was.
The hardware:
- Arduino Mega 2560
https://www.arduino.cc/en/main/arduinoBoardMega2560- Arduino Wireless SD Shield
https://www.arduino.cc/en/Main/ArduinoWirelessShield- Adafruit microSD
https://www.adafruit.com/product/102The microSD has been formatted by right clicking it in my laptop, selecting "Format", unchecking the "Quick Format" option, selecting the FAT32 format and letting it do its thing.
The shield is properly inserted, all the pins are connected at least (I've tested other projects that made use of those pins) and the 6 pins in the middle are connected as well.
I am presently trying to use this example sketch:
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 4;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.print("\nCard type: ");
switch (card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
return;
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("\nVolume type is FAT");
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize *= 512; // SD card blocks are always 512 bytes
Serial.print("Volume size (bytes): ");
Serial.println(volumesize);
Serial.print("Volume size (Kbytes): ");
volumesize /= 1024;
Serial.print("Volume size (Mbytes): ");
volumesize /= 1024;
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
I've tried all the suggested options for chipSelect, as well as 53, 52, 51 and 50.
I've also tried setting the chipSelect pinMode to OUTPUT and did digitalWrite(chipSelect, LOW) or digitalWrite(chipSelect, HIGH) during my attempts.
I've found a lot of threads on this subject, but it seems like they all have different solutions and none of them use the same shield as me.
Thank you in advance for any help you can provide!
