Topic: NVIC_EnableIRQ(PIOD_IRQn) disables serial (Read 577 times) previous topic - next topic
joeblogs
Hey
if the serial monitor (Serial) uses the following pins on the due
PIO_PA8   // PIN 0, URXD
PIO_PA9   // PIN 1, UTXD
why would enabling the port D interrupt stop serial. ie NVIC_EnableIRQ(PIOD_IRQn)
ard_newbie
Enabling PIOD interrupt doesn't stop Serial.
joeblogs
sorry it was writing to PIO_IER that is causing the issues
Code: [Select]
void InputRecorder::enable_trig_interrupts()
TRIG_PIN_PORT->PIO_IDR = 0xFFFFFFFF;
//TRIG_PIN_PORT->PIO_IER |= PIO_PB12;   <--- swapped to b port, this was the offending line
if(actv_trigs[0] != 0)
pmc_enable_periph_clk(TRIG_PMC_CLK_ID);
trigs_are_enabled = true;
NVIC_EnableIRQ(TRIG_PORT_IRQ);
