Topic: ¿How create a library in Arduino? (Read 1 time) previous topic - next topic
diego ulises
I want making a library in arduino, I have not some idea, I Need help.
I do not know where to start and read what is on the official arduino page but I do not understand anything I need a more clear help please
joeblogs
open up some libray files and have a look at them.  they are just a header (.h) file and a source file (.cpp).
the header declares functions variables, and the source file defines the functions.
a library is a collection of variables and functions
OldSteve
Please do not PM me for help. I am not a personal consultant.
And others will benefit as well if you post your question publicly on the forums.
OldSteve
I saw that myself and I did not understand
It's fairly straightforward. Which part didn't you understand?
Did you work through the example and create the 'Morse' library?
PaulS
Quote
Then you are not ready to be creating libraries. When the light comes on, you'll know it, and then you can create a library of your own.
septillion
I can't agree more with PaulS :) Keep learning about writing C/C++ and you'll get there.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
BulldogLowell
Then there are other resources like Adafruit which has a progressive tutorial that begins with some basics here and then introduces classes here.
Learning how to create a class is fundamental to your goal of making a library.  Once you have your class working, putting it into the proper file structure is somewhat trivial.
More people should look at those tutorials...
septillion
But on the other hand, a class != library on it's own. Nor is a library a class per se. A library can also be plain C if you want to.
BulldogLowell
yes, so in that case OP can run straight to the more trivial bits.
TomGeorge
Look at this YouTube, it may help.
https://www.youtube.com/watch?v=fE3Dw0slhIc&t=96s
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
