Topic: Testing to avoid short circuit (Read 402 times) previous topic - next topic
jwills8
I installed a circuit amplifier to my breadboard, to amplify the sound of my buzzer. I used a 9v battery as the power source. I connected it to the positive and negative line. The negative line is connected to ground.
The issue is I have a vibration sensor that can only withstand 3.3v to 5v.
Is there any way to test out whether or not the sensor would work? Without shortcircuiting it?
Thanks
Southpark
#1
May 29, 2017, 03:16 am Last Edit: May 29, 2017, 03:37 am by Southpark
If your vibration sensor requires a DC voltage supply in the range 3.3 V to 5 V, then you could get a voltage-adjustable 'bench' DC power supply to supply the required amount of DC supply voltage to the sensor.
Not sure what you mean by 'without shortcircuiting it'. You're not meant to short circuit anything (in general).
raschemmel
#2
May 29, 2017, 03:52 am Last Edit: May 29, 2017, 03:57 am by raschemmel
Or you could just breadboard an LM-317
(you can replace the unregulated input section with a store bought wall wart dc power supply (ie: 9V)
9v-dc-650ma-wall-adapter-power-supply
LM317-voltage-regulator
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
TomGeorge
Before we get to carried away.
Can you post a picture of your project?
What is your circuit amplifier for your buzzer?
What model Arduino are you using?
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
