Topic: int ret = SigFox.endPacket(); (Read 2036 times) previous topic - next topic
pietervannuffel
May 29, 2017, 04:41 pm Last Edit: Jun 06, 2017, 09:30 pm by pietervannuffel
What is the result of the SigFox.endPacket() function?
In the Sigfox Arduino libraries documentation, you can read the next information:
Quote
Returns an int: 1 if the packet was sent successfully, 0 if there was an error
 if (ret == 1)
   Serial.println("OK");
    Serial.println("KO");
 while (1);
In the "Event trigger" example you find:
Quote
if (ret > 0) {
      Serial1.println("No transmission");
      Serial1.println("Transmission ok");
Which is correct?
facchinm
Hi pietervannuffel,
thanks for spotting this! The EventTrigger example is correct, the function returns 0 if the transmission is ok.
I'll change the documentation of the other page accordingly! Thanks again!
zwanglos
#2
Jul 18, 2017, 04:40 am Last Edit: Jul 18, 2017, 05:31 am by zwanglos
Hey facchinm,
+1.
Short reminder, the documentation (https://www.arduino.cc/en/Reference/SigFoxEndPacket) is still wrong (return value description).
Best,
Daniel
the__j
Hey,
the code seems to be fix now ( 0 = ok ), the return description in the text is not correct.
would be nice to see consistent return values in a lib. SigFox.begin returns 1 = ok.
thanks.
