Topic: Pololu h-bridge  (Read 878 times) previous topic - next topic
titilehippie
May 30, 2017, 11:13 am Last Edit: May 30, 2017, 11:39 am by titilehippie
Hello !!
I need some help with my DRV8835 :
I need to connect 2 DC motors with this h-bridge, but I can't found any working program, (I'm using the DRV8835MotorShield library).
The connections are :
MD -> +5V
IN1 PH A -> pin 51
IN2 EN A -> pin 3 (PWM)
IN1 PH B -> pin 50
IN2 EN B -> pin2(PWM)
VCC-> +5V
VIN-> +6V
GND -> pin (-) of the battery.
This is the DRV8835MotorShield.cpp :
Code: [Select]
#include "DRV8835MotorShield.h"
const unsigned char DRV8835MotorShield::_M1DIR = 50;
const unsigned char DRV8835MotorShield::_M2DIR = 51;
const unsigned char DRV8835MotorShield::_M1PWM = 2;
const unsigned char DRV8835MotorShield::_M2PWM = 3;
boolean DRV8835MotorShield::_flipM1 = false;
boolean DRV8835MotorShield::_flipM2 = false;
void DRV8835MotorShield::initPinsAndMaybeTimer()
  // Initialize the pin states used by the motor driver shield
  // digitalWrite is called before and after setting pinMode.
  // It called before pinMode to handle the case where the board
  // is using an ATmega AVR to avoid ever driving the pin high,
  // even for a short time.
  // It is called after pinMode to handle the case where the board
  // is based on the Atmel SAM3X8E ARM Cortex-M3 CPU, like the Arduino
  // Due. This is necessary because when pinMode is called for the Due
  // it sets the output to high (or 3.3V) regardless of previous
  // digitalWrite calls.
  digitalWrite(_M1PWM, LOW);
  pinMode(_M1PWM, OUTPUT);
  digitalWrite(_M2PWM, LOW);
  pinMode(_M2PWM, OUTPUT);
  digitalWrite(_M1DIR, LOW);
  pinMode(_M1DIR, OUTPUT);
  digitalWrite(_M2DIR, LOW);
  pinMode(_M2DIR, OUTPUT);
#ifdef DRV8835MOTORSHIELD_USE_20KHZ_PWM
  // timer 1 configuration
  // prescaler: clockI/O / 1
  // outputs enabled
  // phase-correct PWM
  // top of 400
  // PWM frequency calculation
  // 16MHz / 1 (prescaler) / 2 (phase-correct) / 400 (top) = 20kHz
  TCCR1A = 0b10100000;
  TCCR1B = 0b00010001;
  ICR1 = 400;
#endif
// speed should be a number between -400 and 400
void DRV8835MotorShield::setM1Speed(int speed)
  init(); // initialize if necessary
  boolean reverse = 0;
  if (speed < 0)
    speed = -speed; // make speed a positive quantity
    reverse = 1;    // preserve the direction
  if (speed > 400)  // max
    speed = 400;
  OCR1A = speed;
#else
  analogWrite(_M1PWM, speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
  if (reverse ^ _flipM1) // flip if speed was negative or _flipM1 setting is active, but not both
    digitalWrite(_M1DIR, HIGH);
void DRV8835MotorShield::setM2Speed(int speed)
  if (speed < 0)
  if (speed > 400)  // max PWM duty cycle
    speed = 400;
  OCR1B = speed;
#else
  analogWrite(_M2PWM, speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
  if (reverse ^ _flipM2) // flip if speed was negative or _flipM2 setting is active, but not both
    digitalWrite(_M2DIR, HIGH);
// set speed for both motors
void DRV8835MotorShield::setSpeeds(int m1Speed, int m2Speed){
  setM1Speed(m1Speed);
  setM2Speed(m2Speed);
void DRV8835MotorShield::flipM1(boolean flip)
  _flipM1 = flip;
void DRV8835MotorShield::flipM2(boolean flip)
  _flipM2 = flip;
and my program...
Code: [Select]
#include <DRV8835MotorShield.h>
 * This example uses the DRV8835MotorShield library to drive each motor with the
 * Pololu DRV8835 Dual Motor Driver Shield for Arduino forward, then backward.
 * The yellow user LED is on when a motor is set to a positive speed and off when
 * a motor is set to a negative speed.
#define LED_PIN 11
DRV8835MotorShield motors;
  pinMode(LED_PIN, OUTPUT);
  // uncomment one or both of the following lines if your motors' directions need to be flipped
  //motors.flipM1(true);
  //motors.flipM2(true);
  // run M1 motor with positive speed
  digitalWrite(LED_PIN, HIGH);
    motors.setM1Speed(400);
    delay(2000);
    motors.setM2Speed(400);
    delay(2000);
   motors.setM1Speed(-400);
    delay(2000);
    motors.setM2Speed(-400);
    delay(2000);
I'm using an Arduino Mega
Thank you for your help !!!
Thierry  :smiley-confuse:  :)
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
titilehippie
Sorry, it's my first post on this forum. I've changed the issue.
Thierry
TomGeorge
Try here where the product came from.
https://www.pololu.com/product/2135
and read this;
"google and yee shall find"
https://codebender.cc/sketch:172232#Pololu%20DRV8835%20Example.ino
Also look in the library examples that come with it, you can find them in   Files, Examples and then click the library name in the list.
Can you tell us your electronics, programming, Arduino, hardware experience?
Tom... :)
titilehippie
Thank you for you answer...
I've already try almost one hundred times this program, but I'm not really sure of the connections between the motor shield, and the arduino Mega ...
We can hear a little sound from the motor, but he doesn't move ...
About my experience, I'm in an engineer school, and I've already used a lot of shields (Bluetooth, 433, Motors, ...) but I don't understand the problem  :smiley-confuse:
Thank you ! :)
Thierry
TomGeorge
Can you please post a copy of your current circuit, in CAD or a picture of a hand drawn circuit in jpg, png?
Label the pins and make sure you include your power supplies.
A picture of your project would help with component layout too.
Thanks.. Tom.. :)
titilehippie
Here you are .......
Thank you so much !!!!  :)
Thierry
MarkT
Try:
Code: [Select]
  pinMode (50, OUTPUT) ;
  pinMode (51, OUTPUT) ;
  analogWrite (2, 100) ;
  analogWrite (3, 100) ;
void loop ()
  delay (1000) ;
  digitalWrite (50, HIGH) ;
  digitalWrite (51, HIGH) ;
  delay (1000) ;
  digitalWrite (50, LOW) ;
  digitalWrite (51, LOW) ;
Which should reverse the motors each second, running at a moderate speed.
TomGeorge
If you are using a SLA battery, PLEASE put a fuse in the positive wire before anything shorts.
The SLA is capable of many amps more than your project can survive.
A blown fuse is cheaper and easier to replace than burnt-out pcbs and wiring.
Tom...  :)
Wawa
The Fritzing picture shows VCC of the motor driver connected to V-in of the Mega. Should be VCC to the 5volt pin.
How is the Mega powered.
If you had >7.5volt on the DC jack, and the motor driver connected like that, then the driver could be toast.
Leo..
