Ok, so I delete all variable Varx, so i should have no problem, but no =/. I found a solution and I think it is not the best.
//PIOB->PIO_CODR = PIO_CODR_P25; // Be sure to start with a low level for output pin
while (true) {
// wait until pin 2 is high
analogWrite(9,delay_value_us);
while ((PIOB->PIO_PDSR & PIO_PDSR_P25) == 0); //wait input become high
// Toggle pin 11
delayNanoseconds(delay_value_us);
PIOD->PIO_ODSR ^= PIO_ODSR_P7; // low to high
PIOD->PIO_ODSR ^= PIO_ODSR_P7; // high to low
while ((PIOB->PIO_PDSR & PIO_PDSR_P25) > 0); //wait input become low
int read_bcd(boolean value1, boolean value2, boolean value3, boolean value4){
//Read BCD wheel, if val1 = 1 and val2,val3 and val4 = 0 so the value is 1
if((value1==LOW)&&(value2==LOW)&&(value3==LOW)&&(value4==LOW)){
value_buffer=0;
else if((value1==HIGH)&&(value2==LOW)&&(value3==LOW)&&(value4==LOW)){
value_buffer=1;
else if((value1==LOW)&&(value2==HIGH)&&(value3==LOW)&&(value4==LOW)){
value_buffer=2;
else if((value1==HIGH)&&(value2==HIGH)&&(value3==LOW)&&(value4==LOW)){
value_buffer=3;
else if((value1==LOW)&&(value2==LOW)&&(value3==HIGH)&&(value4==LOW)){
value_buffer=4;
else if((value1==HIGH)&&(value2==LOW)&&(value3==HIGH)&&(value4==LOW)){
value_buffer=5;
else if((value1==LOW)&&(value2==HIGH)&&(value3==HIGH)&&(value4==LOW)){
value_buffer=6;
else if((value1==HIGH)&&(value2==HIGH)&&(value3==HIGH)&&(value4==LOW)){
value_buffer=7;
else if((value1==LOW)&&(value2==LOW)&&(value3==LOW)&&(value4==HIGH)){
value_buffer=8;
else if((value1==HIGH)&&(value2==LOW)&&(value3==LOW)&&(value4==HIGH)){
value_buffer=9;
return value_buffer;
void pin_ISR() {
delay_value_us_Prec = read_bcd(digitalRead(47),digitalRead(49),digitalRead(51), digitalRead(53))*1000000;
delay_value_us_Prec = delay_value_us_Prec+read_bcd(digitalRead(39),digitalRead(41),digitalRead(43),digitalRead(45))*100000;
delay_value_us_Prec = delay_value_us_Prec+read_bcd(digitalRead(31),digitalRead(33),digitalRead(35),digitalRead(37))*10000;
delay_value_us_Prec = delay_value_us_Prec+read_bcd(digitalRead(23),digitalRead(25),digitalRead(27),digitalRead(29))*1000;
delay_value_ns = read_bcd(digitalRead(22),digitalRead(24),digitalRead(26),digitalRead(28))*100;
delay_value_us= delay_value_us_Prec+delay_value_ns;
If I use AnalogWrite so my value in delay_value_us will be updated in my function, if I use a simple equal it will not work.
Of cours with the analogWrite it works, but with a latency around 400ns between 250 ns without analogwrite.
Thanks for your help ard_newbie, if nobody have idea so I will use analogWrite.
Thanks in advance!
