Topic: Can't install Dropbox SKD on Yun (Read 995 times) previous topic - next topic
simon_schvartzman
Sorry guys if this is too of a dumb question but I'm not familiar at all with Linux.
I have seen a lot of post addressing the Dropbox to Yun connectivity but most of them are rather old and none of them shows how to fix the issue I'm having.
I'm following the instructions I have seen as follows
Code: [Select]
root@Yun28:~# opkg update
which seems to work ok
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.gz.
Updated list of available packages in /var/opkg-lists/attitude_adjustment.
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.sig.
Signature check passed.
Then
Code: [Select]
root@Yun28:~# opkg install distribute
which also seems to go OK
Package distribute (0.6.21-1) installed in root is up to date.
then
Code: [Select]
root@Yun28:~# opkg install python-openssl
again everything seems OK
Package python-openssl (2.7.3-2) installed in root is up to date.
root@Yun28:~# easy_install pip
Searching for pip
Best match: pip 9.0.1
Processing pip-9.0.1-py2.7.egg
pip 9.0.1 is already the active version in easy-install.pth
Installing pip script to /usr/bin
Installing pip2.7 script to /usr/bin
Installing pip2 script to /usr/bin
Using /usr/lib/python2.7/site-packages/pip-9.0.1-py2.7.egg
Processing dependencies for pip
Finished processing dependencies for pip
and  finally
Code: [Select]
root@Yun28:~# pip install dropbox
and this is where I hit the wall
Collecting dropbox
/usr/lib/python2.7/site-packages/pip-9.0.1-py2.7.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:318: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/security.html#snimissingwarning.
  SNIMissingWarning
/usr/lib/python2.7/site-packages/pip-9.0.1-py2.7.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/security.html#insecureplatformwarning.
  Could not fetch URL https://pypi.python.org/simple/dropbox/: There was a problem confirming the ssl certificate: [Errno 185090057] _ssl.c:340: error:0B084009:lib(11):func(132):reason(9) - skipping
  Could not find a version that satisfies the requirement dropbox (from versions: )
No matching distribution found for dropbox
root@Yun28:~#
Not sure what am I doing wrong and any help will be truly appreciated.
simon_schvartzman
I posted exactly the same question on Dropbox forum and I got the following answer:
It looks like this is an issue with 'pip' itself, and not Dropbox, so I'm afraid I can't be of help. It looks like the error message links to some informational pages though, so I recommend reviewing those, and contacting the support or community for pip or PyPI for further help.
Does the above enlightens anybody regarding the solution?
simon_schvartzman
I refuse to accept that there is no solution to access Dropbox from an Arduino Yun !
Yun + Dropbox is a killer combination, how come they don't work together???
Hey Arduino Gurus / Creators / Developers, any hint?
Cheers!
DanielePezzana
got same problem did u find the solution?
