please help i can not upload my sketch to arduino..
hi there
my self sawan, i have made a sketch for arduino but i am unable to upload it,
hardware description
arduino uno , two metal sensor , 4ch relay module but i only using three relays
please see below the sketch..
unsigned long timerStart, timerEnd = 5000;
bool sensorVal= true, previousSensorVal = true;
pinMode(2, INPUT);
pinMode(3, INPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
sensorVal = digitalRead(2);
if (sensorVal != previousSensorVal)
{ // same as (sensorVal == HIGH)
previousSensorVal = sensorVal;
timerStart = millis();
if(sensorVal)
{if(millis() - timerStart > timerEnd)
digitalWrite(11, LOW);
digitalWrite(12, HIGH);
digitalWrite(12, LOW);
digitalWrite(11, HIGH);
sensorVal = digitalRead(3);
if(sensorVal)
digitalWrite(13, LOW);
digitalWrite(13, HIGH);
jaspalsinghh:
What error messages are you getting?
What version of the Arduino IDE are you using?
What PC operating system are you using?
...R
Arduino: 1.8.2 (Windows 7), Board: "Arduino/Genuino Uno"
sketch_jun06a:38: error: 'sensorVal' does not name a type
sensorVal = digitalRead(4);
sketch_jun06a:39: error: expected unqualified-id before 'if'
sketch_jun06a:44: error: expected unqualified-id before 'if'
if(sensorVal)
sketch_jun06a:49: error: expected unqualified-id before 'else'
sketch_jun06a:54: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
You have an extra }
  pinMode(2, INPUT);
   pinMode(3, INPUT);
    if(sensorVal)
} <<< here, so the code that follows is not part of loop()
    if(sensorVal)
SENSOR INPUT 2 WORK BUT 3 DOES NOT WORK , PIN 13 DID NOT RESPOND, PLS HELP
pinMode(2, INPUT);
pinMode(3, INPUT);
if(sensorVal)
if(sensorVal)
Try changing the sensorVal's, etc. associated with digitalRead(3)
to sensorVal1 & previousSensorVal1
Don't you want a."previous" value for each pin?
Don't you want to use code tags?
Don't you want to stop SHOUTING?
INPUT 2 WORK BUT 3 DOES NOT WORK PLEASE HELP.
INPUT 2 ENABLE PIN 11 AND 12 SIMULTANEOUSLY WITH 5 SEC DELAY
INPUT 3 DO NOT ENABLE PIN 13
pinMode(2, INPUT);
pinMode(3, INPUT);
if(sensorVal)
if(sensorVal)
You have two separate pins, each needs its own state variables:
Use an array for this sort of common code:
byte sensorPins[] = { 2, 3 };
bool sensorValue [2] ;
bool previousSensorValue [2];
unsigned long timerStart[2] ;
  for (byte i = 0 ; i < 2 ; i++)
    sensorValue[i] = digitalRead (sensorPin [i]) ;
    if (sensorValue[i] != previousSensorValue[i])
      previousSensorValue[i] = sensorValue[i] ;
      timerStart [i] = millis();
  if (sensorValue[0])
    if(millis() - timerStart[0] > timerEnd)
  if (sensorValue[1])
    if(millis() - timerStart[1] > timerEnd)
Since the two sensors have a different number of output pins to control that wasn't
easy to common up so I didn't. Also you should flag when each timer is active with a
boolean as the timer for each sensor should only be active once after a change.
PS: indent your code properly if you want it to be readable, and no need TO SHOUT IN THE SUBJECT LINE
Why have you started a new thread on the same topic?
Why have you ignored the advice already given?
Why are you still not using code tags?
Why are you still SHOUTING?
jaspalsinghh:
For future reference this is a problem compiling the program and not a problem uploading it. The Arduino will not try uploading a program unless it can compile it without errors.
...R
please refer to the error at the end of the sketch whilke uploading
sensorValue = digitalRead (sensorPin ) ;
if (sensorValue != previousSensorValue*)*
previousSensorValue = sensorValue ;
_ timerStart = millis();
if (sensorValue[0])
digitalWrite(11, LOW);*_
* digitalWrite(12, HIGH); *
* else*
* if(millis() - timerStart[0] > timerEnd)*
* digitalWrite(12, LOW);*
* digitalWrite(11, HIGH);*
* if (sensorValue[1])*
* if(millis() - timerStart[1] > timerEnd)*
* digitalWrite(13, LOW);*
* else*
* digitalWrite(13, HIGH);*
exit status 1
'sensorPin' was not declared in this scope
need this before setup()
byte sensorPin = a number from 2 to 19;
or use this
sensorValue = digitalRead (sensorPins[0] ) ; // or [1]
if you are trying to read from D2 or D3.
jaspalsinghh:
You don't seem to have read Reply #10
...R
dear sir ,
i have red through #10 but did not understood please help.
i think it would be better if i explain in simple language that whati actually i want from arduino uno.
i have got two metal sensor
and four channel relay module
the signal wire of both sensors has been put to d2 and d4 . (d2 sensor# 1 and d4 sensor# 2)
and i only using three relays out of four, has been put to d11 , d12 and d13 .
functionality as per below.
when metal comes in front of sensor #1 the d11 should high other wise(in case metal not there) d12 need to be high.
when metal comes in front of sensor#2 the d13 should high other wise it need to be stay on low.
thats what i really want...
thank you sir,
in simple i would like to add one more sensor to pin #4 with same functionality for pinmode13 output.
my current sketch is given below please edit it for me thank you.
pinMode(2, INPUT);
if(sensorVal)
dear experts please help.
pinMode(2, INPUT);
if(sensorVal)
How many versions of this same sketch are you up to now?
And you're still not used code tags
  pinMode(4, INPUT);
    if(sensorVal)
(deleted)
am sorry sir,
what does mean by code tags.
i want to use both sensor together.
likke you have removed pinmode11 from my program so how come the both sensor work out?
