Topic: error code PLEASE HELP (Read 520 times) previous topic - next topic
arduinoalan
I have gotten this error code several times and I am not sure what it means. Please help me.
code:
Code: [Select]
int ledpin = 12
int sensor = 0
void setup () {
 pinMode(ledpin, OUTPUT);
 pinMode(sensor, INPUT);
 val = analogRead(sensor);       // self-explanitory
 if val <= 12 {                  // if the area is dark enough,
   digitalWrite(ledpin, HIGH);   // Led will come on
 } else {                        // or,
   digitalWrite(ledpin, LOW);    // it won't do anything
the error message at the bottom says:
error: expected unqualified-id before numeric constant In function 'void loop()':
Bad error line: -2
thank you for any help.
Coding Badly
Add semi-colons to these two lines...
Code: [Select]
int ledpin = 12 [glow];[/glow]
int sensor = 0 [glow];[/glow]
arduinoalan
Thank You so much
I had to do a little more and ended up with this.
A program to turn on a light when it is too dark.
Code: [Select]
int ledpin = 12;
int sensor = 2;
int val = 0;
void setup () {
 if (val <= 12) {                // if the area is dark enough,
 } else {                        // or,
