Topic: Error in the library  (Read 2890 times) previous topic - next topic
pert
Please delete C:\Users\User\Documents\Arduino\libraries\Cayenne
I think we have one more error to fix after this and then it will compile.
roccol00
#16
Jun 12, 2017, 01:08 pm Last Edit: Jun 12, 2017, 01:15 pm by roccol00
Arduino \ Tools C: \ Program Files (x86) \ Arduino \ Tools C: \ Program Files (x86) \ Arduino \ Hardware Tools: Arduino: 1.8.3 (Windows 7), Card: "Arduino / Genuino Uno" \ Arduino \ arduino \ builders -dump-prefs -logger =
C: \ Program Files (x86) \ Arduino \ libraries -libraries C: \ Users \ User \ Documents \ Arduino \ Arduino \ hardware \ tools \ avr -built-in-libraries \ Libraries -fqbn = arduino: avr: a -ide-version = 10803-building script
C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_588125 -warnings = none -build-cache C: \ Users \ User \ AppData \ Local \ Temp \ arduino_cache_5469 -prefs = build.warn_data_percentage = 75 -prefs = runtime.tools.avrdude.path =
C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -prefs = runtime.tools.arduinoOTA. C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -verbose C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -prefs = runtime.tools.avr-gcc.path = \ Arduino \ arduino-builder -compile -logger = machine-hardware C: \ Program Files (x86) \ Arduino \ hardware-tools C: \ Program \ \ Arduino \ tools-builder C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -built-in-libraries C: \ Program Files (x86) \ Arduino \ libraries -libraries C: \ Users \ User \ User \ AppData \ Local \ Temp \ arduino \ libraries C: \ Users \ User \ AppData \ Local -fqbn = arduino: avr: a -ide-version = 10803 -course
 C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_588125 - Warnings = \ temp \ arduino_cache_5469 -prefs = build.warn_data_percentage = 75 -prefs = runtime.tools.avrdude.path = C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr -prefs = runtime.tools.arduinoOTA.path = \ Ard Hardware \ tools \ avr -prefs = runtime.tools.avr-gcc.path = Machine \ New folder (2) \ machine \ hardware \ tools \ avr -verbose E: \
C: \ Program Files (x86) \ Arduino \ (Arsenal) \ Arduino \ arduino \ avrUse the 'arduino' core from the platform into the folder: C: \ Program Files (x86) \ Arduino \ Hardware \ Arduino \ avrReading used libraries ... "C: \ Program Files (x86) \ Arduino \ hardware \ tools \ avr / bin / avr-g ++" -c -g -Os -w -std = gnu ++ 11 - (-fc-threadsafe-statics -flto -w -xc ++ -E -CC -mmcu = atmega328p -DF_CPU = 16000000L -DARDUINO = 10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC: \ Programs ( X86) \ Arduino \ hardware \ Arduino \ avr \ cores \ arduino "" -IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ variants \ standard ""
C: \ Users \ User \ AppData \ Local \ Temp \ Arduino_build_588125 \ Arduino \ hardware \ tools \ avr / bin / avr-g ++ "-c -g -Os -w -std = \ sketch \ machine.no.cpp" -o "nul" "
C: \ Program Files (x86) Gnu ++ 11 -fpermissive -fn-exceptions- Fdata-sections -fno-threadsafe-statics -flto -w -xc ++ -E -CC -mmcu = atmega328p -DF_CPU = 16000000L -DARDUINO = 10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR " IC: \ Program Files (x86) \ Arduino \ hardware \ Arduino \ avr \ cores \ arduino "" -IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ variants \ standard " \ Arduino \ libraries \ Servo \ src ""
C: \ Users \ AppData \ Local \ Temp \ arduino_build_588125 \ sketch \ machine.ino.cpp "or" nul "" C: \ Program Files (x86) \ Arduino \ Hardware-tools-avg-bin-avg-g ++ -c -g -Os -w -std = gnu ++ 11 -fpermissive -none-exceptions- Fdata-sections -fno-threadsafe-statics -flto -w- Xc ++ -E -CC -mmcu = atmega328p -DF_CPU = 16000000L -DARDUINO = 10803 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC: \ Program Files (x86) \ Arduino \ hardware \ Arduino \ avr \ cordues \ arduino "" -IC: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ variants \ standard "" -IC: \ Program Files (x86) \ Arduino \ libraries \ Servo \ src "
C : \ Users \ User \ AppData \ Local \ Temp \ arduino_build_588125 \ preproc \ ctags_target_for_gcc_minus_e.cpp "" C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_588125 \ sketch \ machine.ino.cpp "E: \ machine \ Folder (2) \ machine \ machine.ino: 3: 103: fatal error: BlynkSimpleShieldEsp8266_SoftSer.h: No file or directory #include <BlynkSimpleShieldEsp8266_SoftSer.h> // Set ESP8266 serial object ^ Completion is finished.Using the Servo Library To version 1.1.2 in the folder:
C: \ Program Files (x86) \ Arduino \ libraries \ ServoOutput Status 1Error When compiling for the Arduino / Genuino Uno card.
I've deleted the cayenne library and now I get this error
pert
It seems like we're going in circles here. Please do this:
roccol00
#18
Jun 12, 2017, 04:49 pm Last Edit: Jun 12, 2017, 05:31 pm by roccol00
"C: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_604642 \ libraries \ Cayenne \ utility \ utility.cpp.o" \ Local \ temp \ arduino_build_604642 \ libraries \ Cayenne \ utility \ BlynkHandlers.cpp.o " \ User \ AppData \ Local \ Temp \ arduino_build_604642 / core \ core.a "" -LC: \ Users \ User \ AppData \ Local \ Temp \ arduino_build_604642 \ libraries \ SoftwareSerial \ SoftwareSerial.cpp.o " Users \ User \ AppData \ Local \ Temp \ arduino_build_604642 "-lm
C: \ Users \ User \ AppData \ Local \ Temp \ cckLBQTg.ltrans3.ltrans.o: In function `__static_initialization_and_destruction_0 ':
E: \ machine \ New folder (2) \ machine / machine.in: 8: undefined reference to `ESP8266 :: ESP8266 (SoftwareSerial &) '
Collect2.exe: error: ld returned 1 exit status
I use the Servo library to version 1.1.2 in the folder: C: \ Program Files (x86) \ Arduino \ libraries \ Servo
I use the Cayenne Library to version 0.3.4 in the folder: C: \ Users \ User \ Documents \ Arduino \ libraries \ Cayenne
I use the SoftwareSerial library to version 1.0 in the folder: C: \ Program Files (x86) \ Arduino \ hardware \ arduino \ avr \ libraries \ SoftwareSerial
Exit status 1
Error while compiling for Arduino / Genuino Uno board.[code]
I always get the same error.
pert
And now the Cayenne library is back... Why do we keep going in circles here? It's getting tiresome trying to help you.
