Topic: pH Meter problem (Read 2956 times) previous topic - next topic
Wecuyx
I have a temperature and pH sensor connected to my Arduino Uno Wifi with a Base Shield 2.0. On the Base Shield, there is a switch for 3.3v and 5v. If the switch is towards 3.3v, i will have a normal pH value(Water: about 7.0) but my temperature value will be low as 17Degrees(Suppose to be around 32).
If i switch to 5V on my Base Shield, My pH value will increase up to around 9-10 pH value while my Temperature will be correct. How can i adjust so that i will have both value correct?
Wecuyx
This is my Sketch for pH and Temperature:
# This sample code is used to test the pH meter V1.0.
# Editor : YouYou
# Ver    : 1.0
# Product: analog pH meter
# SKU    : SEN0161
#define SensorPin A0            //pH meter Analog output to Arduino Analog Input 0
#define Offset 0.00            //deviation compensate
#define LED 13
#define samplingInterval 20
#define printInterval 800
#define ArrayLenth  40    //times of collection
int pHArray[ArrayLenth];   //Store the average value of the sensor feedback
int pHArrayIndex=0;
//Temperature
int a;
float temperature;
int B=3975;                  // B value of the thermistor
float resistance;
void setup(void)
 pinMode(LED,OUTPUT);
 Serial.println("pH meter experiment!");    //Test the serial monitor
void loop(void)
 static unsigned long samplingTime = millis();
 static unsigned long printTime = millis();
 static float pHValue,voltage;
 if(millis()-samplingTime > samplingInterval)
     pHArray[pHArrayIndex++]=analogRead(SensorPin);
     if(pHArrayIndex==ArrayLenth)pHArrayIndex=0;
     voltage = avergearray(pHArray, ArrayLenth)*5.0/1024;
     pHValue = 3.5*voltage+Offset;
     samplingTime=millis();
 if(millis() - printTime > printInterval)   //Every 800 milliseconds, print a numerical, convert the state of the LED indicator
 Serial.print("Voltage:");
       Serial.print(voltage,2);
       Serial.print("    pH value: ");
 Serial.println(pHValue,2);
       digitalWrite(LED,digitalRead(LED)^1);
       printTime=millis();
//Temperature
   a=analogRead(1);                            // get analog value
   resistance=(float)(1023-a)*10000/a;                      // get resistance
   temperature=1/(log(resistance/10000)/B+1/298.15)-273.15;     // calc temperature
   delay(1000);                                                 // delay 1s
   Serial.print("Current Temperature is ");
   Serial.println(temperature);
double avergearray(int* arr, int number){
 int i;
 int max,min;
 double avg;
 long amount=0;
 if(number<=0){
   Serial.println("Error number for the array to avraging!/n");
   return 0;
 if(number<5){   //less than 5, calculated directly statistics
   for(i=0;i<number;i++){
     amount+=arr;
   avg = amount/number;
   return avg;
 }else{
   if(arr[0]<arr[1]){
     min = arr[0];max=arr[1];
   else{
     min=arr[1];max=arr[0];
   for(i=2;i<number;i++){
     if(arr<min){
       amount+=min;        //arr<min
       min=arr;
     }else {
       if(arr>max){
         amount+=max;    //arr>max
         max=arr;
       }else{
         amount+=arr; //min<=arr<=max
     }//if
   }//for
   avg = (double)amount/(number-2);
 }//if
 return avg;
jremington
Please edit your post to add code tags ("</>" button).
This line assumes that the voltage reference value is 5V. Is it at all times?
Code: [Select]
allanhurst
What is a 'base shield'? what are it's specifications?
without this we can't help.
Allan
hadzim
 # Editor : YouYou
 # Ver    : 1.0
 # SKU    : SEN0161
#define Offset 0.00            //deviation co*******2mpensate
#define LED 13
int pHArrayIndex=0;
const int buzzer = 9;
void setup(void)
  pinMode(buzzer, OUTPUT);
void loop(void)
  if(pHValue <=4.0){
    digitalWrite(buzzer,HIGH);
  if(pHValue >4.0){
   digitalWrite(buzzer,LOW);
        printTime=millis();
  int i;
  int max,min;
  double avg;
  long amount=0;
  if(number<=0){
    Serial.println ("Error number for the array to avraging!/n");
    return 0;
      amount+=arr;
    return avg;
  }else{
    if(arr[0]<arr[1]){
    else{
      if(arr<min){
        min=arr;
      }else {
        if(arr>max){
          max=arr;
      }else{
      }//if
    }//for
  }//if
  return avg;
Delta_G
Are you sure your water should read at 7?  While that is theoretical neutral water, it would be quite unusual to measure that value without buffering the water to maintain it.  Normally water out of the tap is around the high 8's or even low 9's depending on corrosion control measures.
Get a known pH standard to check against.  You can't use water.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
