Topic: Burning bootloaders on Atmega2560V-8AU (Read 2628 times) previous topic - next topic
mudassir9999
Hello everyone,
I purchased Atmega2560V-8AU chip and want to burn nick gammon bootloaders to it.
My question : can I use Arduino Mega to upload bootloaders to it? I asked it because , Mega uses 5V and my target chip works on 3.3V is that makes any error or heating to my chip? And also I want to upload my sketch into it using Arduino UNO without chip.
Does my idea works?
Thank you
Budvar10
The 2560V is 5V tolerable chip but what about other parts in your circuit. If the whole circuit is 5V tolerable, then yes. Of course, you cannot use it if the chip is powered by 3V3, 5V signal will destroy the IOs.
In any case, you can use some kind of voltage lever converter.
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
mudassir9999
Thank you very much for reply,
I will try using bi-directional logic level shifter like BSS138 module.
Is this module works on reset line of SPI and UART as well?
Budvar10
mudassir9999
Thank you very much again
Quote
.     While we designed it for use with I2C, this works as well for  TTL Serial,  slow <2MHz SPI
Is Arduino SPI works <2Mhz ?
CrossRoads
Arduino SPI works at clock speeds of system clock divided by 2,4,8,16,32,64, 128,and maybe 256. /4 is the default, /2 is the fastest.
System clock of 8 MHz/4 = 2 MHz.
hansibull
The ATmega2560V can't operate at more than 8 MHz, so the original Arduino MEGA 2560 bootloader won't work. You should probably check out MegaCore. It let's you run the ATmega2560V at 8 MHz, and got a bootloader as well. https://github.com/MCUdude/MegaCore. You'll also get 16 more IOs, and lots of other useful settings as well.
Quote
Really? You're overcomplicating things. The IOs are 5V tolerant, the problem is the protection diodes. They will clamp voltages higher than Vcc to prevent damage. All you need to do is to add a current limiting resistor in series, and volá, your pin is now 5V compatible. I'd say 220Ω or more.
MightyCore -  ATmega1284, mega644, mega324, mega164, mega32, mega16, mega8535
Github.com/MCUdude/MightyCore
MiniCore - ATmega8, mega48, mega88, mega168, mega328
Github.com/MCUdude/MiniCore
mudassir9999
#7
Jun 09, 2017, 02:19 pm Last Edit: Jun 09, 2017, 03:09 pm by mudassir9999
@hansibull
If i use megacore boards, then i don't have to use Voltage level shifter.?
I am using Arduino as ISP programmer
mudassir9999
Hello,
I have tried using Arduino as ISP programmer i got some error here, I used both internal and external crsytal settings
Quote
Arduino: 1.8.1 (Windows 10), Board: "ATmega2560, Arduino MEGA pinout, 2.7v, Disabled (default), 8 MHz internal"
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-avr-100-pin\avr/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
option enabled in File -> Preferences.
mudassir9999
Hello,
Quote
         Using Port                    : COM6
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
         this check.
Note : I am powering up my atmega2560v with +5V
mudassir9999
Hello there,
I am trying to upload blink sketch in my Arduino Mega using Megacore board.
I used this settings in the drop down menus.
Board : Atmega2560
BOD : 2.7V
pinout : Arduino MEGA pinout
clock : 16Mhz External
Compiler LTO : disable(default)
Port : **The one which arduino mega is attached to**
Programmer : USBasp
I get the below error.
Quote
Arduino: 1.6.13 (Mac OS X), Board: "ATmega2560, Arduino MEGA pinout, 2.7v, Disabled (default), 16 MHz external"
Sketch uses 1,564 bytes (0%) of program storage space. Maximum is 261,120 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8,183 bytes for local variables. Maximum is 8,192 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
when i used standard settings to upload sketches, It uploads and works.
what could be the reason?
Thanks
hansibull
Are you able to burn the bootloader? Open the IDE settings and enable verbose upload. Try burning the bootloader after setting the correct clock settings, and post the complete output. I guess there's some kind of communications issue. Don't think it's related to the voltage difference.
mudassir9999
#12
Jun 09, 2017, 09:35 pm Last Edit: Jun 09, 2017, 09:37 pm by mudassir9999
Hello hansibull,
Quote
No! I am not able to burn bootloaders, i am first trying to upload blink sketch using megacore board on ARduino Mega.
I tried to upload a blink sketch to my Arduino Mega and it doesn't uploads.
here is the output : Please see attached .txt file with this comment..
as i cannot use more than 9000words in the comment, I made output in .txt file.
Thank you
hansibull
Quote
This is not the output from the "Burn bootloader" session, this us the output from a regular upload. Of course this wouldn't work if the correct bootloader isn't installed. You need to connect an ISP programmer to your Arduino MEGA, and burn the bootloader with the correct clock frequency. I need to see the output of THAT.
mudassir9999
Hello Hansibull,
I have done as you have said the output i get is below, When i hit burn bootloaders it's giving me the same error, I have "Tick" to the vebrose in preferences.
Quote
Arduino: 1.6.13 (Mac OS X), Board: "ATmega2560, Arduino MEGA pinout, 2.7v, Disabled (default), 8 MHz internal"
/Users/mudassir/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8/bin/avrdude -C/Users/mudassir/Documents/Arduino/hardware/MegaCore-avr-100-pin 2/avr/avrdude.conf -v -patmega2560 -cstk500v1 -P/dev/cu.usbmodem1421 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd6:m -Ulfuse:w:0xe2:m
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:32:25
         System wide configuration file is "/Users/mudassir/Documents/Arduino/hardware/MegaCore-avr-100-pin 2/avr/avrdude.conf"
         User configuration file is "/Users/mudassir/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem1421
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading | ################################################## | 100% 0.03s
         this check.
