Topic: Burning bootloaders on Atmega2560V-8AU (Read 2626 times) previous topic - next topic
hansibull
#15
Jun 10, 2017, 03:07 pm Last Edit: Jun 10, 2017, 03:08 pm by hansibull
Quote
avrdude: Device signature = 0x000000 (retrying)
Something is wrong with your connection. The programmer can't communicate with the device - at all. If the programmer can't communicate with the device, no bootloader is installed. No bootloader, no USB uploading.
Double check your wires, and make sure there's proper contact beween the programmer and the MEGA. Note that the MISO, MOSI and SCK on the MEGA is pin 50, 51 and 52
MightyCore -  ATmega1284, mega644, mega324, mega164, mega32, mega16, mega8535
Github.com/MCUdude/MightyCore
MiniCore - ATmega8, mega48, mega88, mega168, mega328
Github.com/MCUdude/MiniCore
mudassir9999
#16
Jun 10, 2017, 09:43 pm Last Edit: Jun 10, 2017, 09:57 pm by mudassir9999
Hello Hansibull,
I have successfully uploaded bootloaders to my ATmega2560V-8AU, But I used +5V supply to burn bootloaders..
Here is the full log, Please see attachedd .TXT file
Thank you
Note : I have still didn't tested uploading code using UART :)
P.S I have burn bootloaders twice for confirmation :p
mudassir9999
Hello Hansibull,
I have have uploaded my code into the ATmega2560V but using Arduino as ISP programmer (BY HOLDING THE SHIFT KEY! and UPLOADING)..
is there any way i can upload using Hardware Serial (UART) .? linke normal ARduino does.?
and if i tried to upload using Hardware Serial (UART), I get below output.. see .txt file
thank you
mudassir9999
#18
Jun 11, 2017, 08:37 pm Last Edit: Jun 11, 2017, 08:46 pm by mudassir9999
Hello Hansibull,
I have just uplaoded my GPS sketch which Serial prints Lattitude and longitude data into Serial Monitor using Arduino as ISP programmer - I can now see what i am printing on Serial Monitor like Latitude and Longitude data etc., when i attach Hardware Serial pins to my Arduino UNO (without Chip) but I  am not able to upload Sketch using my UART port..
What could be the reason.?
The connections looks perfect to me.
Please help.
Thanks
hansibull
How does your hardware look like? MegaCore uses PE0 and PE1 for serial upload. When you're shift+uploading the code, you're erasing the bootloader. You need to re-burn it, and then upload without holding shift. If it still doesn't work it's most likely your auto reset functionality. should be a 100n capacitor in series between DTR on the USB to serial adapter and the RST pin on the ATmega2560
mudassir9999
Hello hansbull,
I don't know what is wrong here, but when I tested my Atmega 2560-16AU with nick gammon bootloaders it works but when I tested it with mega core with 16mhz crystal and hit burn bootloaders  it doesn't.
Note : I have used Arduino as ISP second time.
Is there any way that I can customise nick gammon bootloaders for Atmega 2560v ?
Help needed
Thanks
mudassir9999
When i try using mega core now, it's showing me this outout
Quote
Arduino: 1.8.1 (Windows 10), Board: "ATmega2560, Arduino MEGA pinout, 2.7v, Disabled (default), 8 MHz external"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-avr-100-pin\avr/avrdude.conf -v -patmega2560 -cstk500v1 -PCOM6 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd6:m -Ulfuse:w:0xf7:m
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-avr-100-pin\avr/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x80ffff
avrdude: Expected signature for ATmega2560 is 1E 98 01
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
hansibull
It's your connection. It's not reliable
mudassir9999
Hello hansibull,
you are right, My connection is not reliable - Recently i have attached SD card to my PCB via Lvc125a buffer chip, That might be the reason it's not working in my case.
I have now got a new Chip soldered to new PCB with 8Mhz Crystal, I hit to the burn bootloaders using Arduino as ISP and i got this error
Quote
Arduino: 1.8.0 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\mudas\Desktop\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avrdude -CC:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-avr-100-pin\avr/avrdude.conf -v -patmega2560 -cstk500v1 -PCOM6 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd6:m -Ulfuse:w:0xf7:m
         Using Port                    : COM6
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xfd"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xfd:
avrdude: load data efuse data from input file 0xfd:
avrdude: input file 0xfd contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xd6"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd6:
avrdude: load data hfuse data from input file 0xd6:
avrdude: input file 0xd6 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xf7"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xf7:
avrdude: load data lfuse data from input file 0xf7:
avrdude: input file 0xf7 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: verification error, first mismatch at byte 0x0000
         0xee != 0xf7
avrdude: verification error; content mismatch
mudassir9999
Hold on!!!
I have played with the board.txt file... Now i have replaced it with then new one and it just works now...
Wait untill i get back to with the uploading of sketch using UART
thank you
mudassir9999
Hello Hansibull,
UART is also working.!!! THanks man thanks a lot
